Awesome!! I think I will wait until the stable version is released to flash but I'm really happy to see this.
Also, JDLFG has a new set of CM-specific kernels for the CM6 RC...I can't find his feature list, but I know he said that among other things, they integrate a "powersave" feature.
These are listed as test kernels by jdlfg. I did do a nandroid before installing, something I usually don't do for a kernel.
I'm running the 1050 w/out issue. Got a 1250 quadrant, highest I've ever gotten w/a 1050. Wifi works fine.
Again, these are for CyanogenMod only.
Test Kernels v.32.2.2cm
800: http://bit.ly/aid7KO
900: http://bit.ly/d6RnoH
950: http://bit.ly/dquYIe
1000: http://dl.dropbox.com/u/6011176/omap.v.32.2.2/jdlfg1000.v.32.2.2cm.zip
1050: http://bit.ly/do4Lwi
1100: http://dl.dropbox.com/u/6011176/omap.v.32.2.2/jdlfg1100.v.32.2.2cm.zip
1150: http://bit.ly/brIsTX
1200: http://bit.ly/blZ1sE
1250: http://bit.ly/a12bqV
Sweet are they in RomManager?
I don't know, haven't looked. If they are they would be labeled 2.2...likely not, if he still has them in "test" stage.
Just use chrometophone to send this page to your phone, click the link to download, and use ROM Manager to install zip from SD card... easy-peasy.
20 minutes after the 1250, I got a 1283 Quadrant.![]()
i have been a loyal CM flasher for a while. this time i was a little hesitant since i had been running jrummy's newest source rom and it was running awesome. well i flashed this, put fab's x theme with the modded black bar and then flashed chevy's ulv 1000 kernel and after putting the SU2.1 back on, this is now my favorite rom.
An issue I had at first was not being able to switch wallpapers?
Apparently, it is necessary to "reboot" (at least on my Droid), then the new wallpaper shows up. Not overly inconvenient since there is a reboot option when the power key is long-pressed.
Yep. I reboot and wallpaper shows up. I have a feeling this will be fixed in the next release
So far I have just had to restart Launcher Pro vs. the entire phone to get the Wallpaper to change.
anyone else notice some protected apps not showing up in the market? tried bgill's market fix as suggested but that just gave me a boot loop.
That is an issue w/2.2 ROMs, depending on what's in the...hmmm, IRRC, it's the build.prop file, to identify what ROM it is.
The "market fix" simply sets the value so that it looks like a 2.1 ROM to the market...no idea why it boot looped you, unless the fix replaces the entire build.prop and it's no longer compatible (the fix was created a while back when the 2.2 ROMs first started appearing).
yeah the rom rocks even with this minor issue. market worked fine on jrummy's source 2.2 but oh well. hopefully this will be resolved soon.
EDIT: after trying the market fix a second time i can confirm that it works to show protected apps.
Market update fix for Froyo leaked version 2 - Droid Forum - Verizon Droid & the Motorola Droid Forum
Can you post a link to the file? Also if I flash a n ew rom will I have to reflash the fix?
