iowabowtech
root@android:/ #
yes (though I used mybackup root instead)
on another forum I was told to format the card from inside cyanogen mod,, so I tried that
yikes, now I am stuck with the blue Cyanogen mod reboot loop. is it safe to pull the battery and reinstall?
Yeah, I edited my last post but evidently not in time so check it out. You can battery pull, then reinstall battery. Hold volume down while pressing power button to get into hboot. Then select recovery to get back into Clockwork. Then do all the wipes I mentioned before loading the Rom/Gapps. No problem, you're fine.
