mavrikmeercat
had to be the problemyeah but i dont think i was it wasn't giving me a notification. i think the folder was the problem
Whats so special about this ROM? its missing a lot of apps, i guess that is for speed. Can someone give me a good reason to keep this loaded?
And what do i put in the Domain/Username: input box for domain?
i use to think it wasn't worth it until i finally knew how to use it. now ill never go back. its better all around, plus its cyanogenmod mannnnnnnnnnnn
just give it a try man youll love it trust me. if you have any questions just post it, everyone is more than welcome to help you out
i gave it a try i dont know how to install apps without searching google, how to sync my contacts, ect ect
I'm havingAnother problem I've come across is how SLOW my 3G is. Seems I was getting better 3G back when I was on stock. I don't know if that was due to the PRL update or maybe I'm missing something. Either way it is noticeable that my 3G is much slower now.
I've read there some people are using some sort of 3G script to boost their performance, though I don't know where the link to it is. Also I'm sure it's just something really minor that will be fixed in a hotfix.
So far really the only problems I've been having is the MMS issue while WIFI is on. The GPS issue that can be fixed with FasterFix and GPSFix (uninstall this sucker quick) from the Market. Also once in awhile my phone takes forever to load cause it gets stuck on the Android_ screen and reboots once or twice. Not all the time though just sometimes. Not sure what's causing that really. Once those issues get solved I think I should be good
Any suggestions Hoark on scripts or possible fixes I can do?
I believe what you're looking for can be found fron here.Oh ok i see now, but is there a tutorial on how to customize it so much?
and this does seem great, flashing now, hrorak you are the man!
Just want to start by saying I LOVE YOU GUYS!![]()
I just want to help by letting you guys know what my issues are so far to help trouble shoot.
1.) Reboots and start ups will get to the "ANDROID_" screen and then reboot about 4 or 5 times before it gets to the main boot animation. Also the main boot animation takes about 5 minutes to finish up. So my reboots are a 10 minute process
2.)I installed Smart Keyboard Pro and after I change my input method to Smart Keyboard it lasts about an hour or so and then reverts back to the stock keyboard and changes it to seem like I never selected to use the Smart Keyboard.
3.)My AMW Launcher FC's about 7 or 8 times in a day. I turned off "Wallpaper Hack" which says that it will help stop the FC but it lied
4.)The clock on the status bar is always showing on top of anything that runs inside my status bar. (Kind of annoying just wanted to let you know if you had a quick fix)
5.)3g animation doesn't budge for anything (Just curious if that can be quick fixed)
6.)Haptic Feedback for the hard keys don't work on press or release just on long-press. I tried changing the settings in but it they just don't respond to anything but long-press.
7.)I've also noticed that alot of the settings don't always stick. Its like it forgets what your settings are once and awhile but then it will correct itself after. Its weird I think there might be some kind of override writing issue. Idk but I'll be setting up a ubuntu system here soon to help break down some of this code (don't count on it though I'm mostly busy until I sleep)
That about does it for now. I've been running the mod for about a week now and it seems to be doing great.
My specs:
CyanogenMod
Ultra Blue Theme
CWM 5
3g boost script
v6 supercharger script
A2sd and s2e
Hey guys noticed its been quite in here....,
I found a new issue with the launcher. if u have the app drawer open and rotate the screen the launcher will crash.
this does not happen on mine
must be some app you installed or config change you made
Does your Menu, Home, Back and Search button vibrate when you touch them? And does it vibrate when you get a call or notification?
no
I have not had a chance to look into that yet
no
Mine worked about 5 times. I use it to connect my galaxy tab. I was gonna post a screenshot to say it works last night but when I tried I couldn't even get it to pick up a signal. Now its doing th exact same thing as yours.not sure about the launcher. if i rotate the screen Then open launcher its fine. but if the screen rotates with it open it crashes.
on another note, i know theres a thread here but i need some info.
does anyone have wireless tether working in AP mode. on cm7 or the phone for a fact?!?
i can get it to load, connect my computer. and see data being sent but none recieved.
The reason im wondering if Boost hasnt bocked me is b/c in AP mode my data counter sees that the phone is tethering. but in adhoc mode it dosent see that im tethering. if anyone has this working or if we could get the built in one in cm7 working it would be great!
here is a screenshot of it running in AP mode with upload data going but no download.
