Guys, im running v3.5 with hotfix 2 and i cant seem to get s2e to work. i cant even get a read on sd-ext
i added the new hot fix i now i got the symbol and the sugestion prompt come up when i turn it on i get nothing on my computer
great job! hroark13
which of my previous suggestions have you tried?
I added the hot fix and I rebotted everything n switch usb port
may be that mount script is conflicting with s2e
can you uncheck the option in s2e to mount ext4 and then reboot phone
nope nothing worked. havent been able to use it in any of your previous versions of cm7. i also get an error formatting my sd-ext in cwm
what did you use to partiton the sdcard
dude s2e works but when you try to save settings on the phone in any menu it doesn't save. thats the main issue
it works for me
but in s2e I only select Applications and Private apps
All i used was cwm, should i format as ext4 in mintfree or easeus partition programs
what size / class is your sd card
what size partiton did you choose when you partitioned it, i would backup up your important data on it, and try partitioning it again in CWM
I would not make any bigger than 1 GB
I do have a cheap 32gb class 4 from china partitioned from cwm as ext 1024mb and 0mb swap
i was moving all options im going to try your suggestion.
for the record a2sd beta 4 dosent work with this version when you try to enable wireless settings it just freezes up and then says error
class 4, umm that a little slow
I am not saying that is your problem, but stilll
if you cant format the ext in CWM there is an issue
backup important stuff
use mini tool to delete all partitions on it
then partition in CWM
then format sd-ext in CWM
you should consider a faster card too
nice score, i dont think i got that high yet, but pretty close
what mods/ apps / settings did you do
