Root CyanogenMod 7 Unofficial Beta 5 02/20/12
can you down load an app from the Market called APN Manager and install, and open it
Then go into APN List
tell me if you have any APNs
if you have one for Boost
do long press on it and select edit
and tell me what it says
thanks
Boost_Mobile
Apn Boost_Mobile
Proxy
port
user name Boost_Mobile
password *
server*
MMSC http://mm.myboostmobile.com
MMSProxy 68.28.31.7
MMS Port 80
MCC 310
MNC 00
APN Type
I re flashed the ROM and tried the mms with out the wifi this time it worked. Thanks alot. Will there be a way to fix it so it works with wifi?
When I try to install the zip, it aborts the installation and it says " (bad) "
So just a corrupted download?
Also, the Megaupload link ins unavailable.. Thank you sir for your time..
Working great only have a few things to bring up...
1. A2SD installs correctly but for some reason only shows a 160MB sdext. I partitioned as 1GB EXT 2 with EaseUS because CWM wasnt letting me partition for some reason.
2. Is there any way to add more than 3 dock Icons with ADW?
3. Removed. Bloodawn's gingerbread keyboard for simple green WAS working on this until reboot. Then constant FC. :( I miss you beautiful keyboard.
3. I would like to point out that Bloodawn's Gingerbread keyboard for simple green on shabbymod 0.9 works for this.
1. hmm i will have to look into the CWM partition thing
2. settings - ADWLauncher - UI Settings - Main Dock Style - 5 icons
Heres a tip that works for me regarding the 3G connection issue.
Go into Cyanogen Settings and find the Power Notification settings.
Add a widget to enable/disable 3G to the power bar.
Now all you have to do after reboot is pull down your notifications and disable then enable 3G and you'll have data.
Anyone else try this?
Hope it helps out!
Hope it helps out!
mines actually came this way in the notification bar.
anyone tried any Bluetooth transfers? i connected a Bluetooth headset, no probs. Can make calls on it, works good. But pairing with another device, same phone, Havent been able to transfer any typa a file i tried, between the two phones.
Just fails on transer.
just curious, but my market connection to the phone through the internet doesn't recognize the phone. is this expected? I can still download through market on phone. But can't push apps from the desktop/web.
not really sure, i haven't checked that out.
if the 3g icon shows up on boot does that mean it works? cuz mine always shows it on start up.
check thru your browser. typa a site. if it works. 3g is on. i know the icons changes colors sometimes when connected, but if u run the browser & pages load up, 3g is workn..
anyone having trouble getting voicemail to work through boost after installing this?
mine is saying check the number you have dialed?
yes i did. a couple of times. But I did a factory reset, Hroark kernel, then set accounts, let everything sync, listened to that pesky voicemail before Hroarks cm upgrade, then followed all tips to upgrade. It worked for me.
go into settings/call settings. voicemail settings. i changed where it says *86 to my #.
Sorry for double post.. didn't notice.. is there a actual code like the *86 that actually triggers the vmail...
So far here are my issues. Hopefully you can help.
1. Busybox says null, no version installed. Then when i try to install it, it says it cant mount /system/xbin/ to RW
2. Root Explorer is just a black screen that FC's
3. A lot of root apps not really working.
Its like I lost root permissions but i can still access /
Anyone else have these problems or know how to fix it?
I followed hroarks guide to the "t" and im not sure where to go from here.
