Root CyanogenMod 7 Unofficial Beta 5 02/20/12
just curious, but my market connection to the phone through the internet doesn't recognize the phone. is this expected? I can still download through market on phone. But can't push apps from the desktop/web.
yep i saw the same on mine .. web market says app installed and won't allow you to choose phone to reinstall ..
So far here are my issues. Hopefully you can help.
1. Busybox says null, no version installed. Then when i try to install it, it says it cant mount /system/xbin/ to RW
2. Root Explorer is just a black screen that FC's
3. A lot of root apps not really working.
Its like I lost root permissions but i can still access /
Anyone else have these problems or know how to fix it?
I followed hroarks guide to the "t" and im not sure where to go from here.
did you install any of the hot fixes?
Heres a tip that works for me regarding the 3G connection issue.
Go into Cyanogen Settings and find the Power Notification settings.
Add a widget to enable/disable 3G to the power bar.
Now all you have to do after reboot is pull down your notifications and disable then enable 3G and you'll have data.
Anyone else try this?
Hope it helps out!
Much easier, works like a charm. Thank you so much!
i did. should i try and start over fresh? or any other suggestions?
no need to start over
I am not sure what is causing the issue, I would imagine some type of mounting issue
I could alway make it so that the /system partition mounts as RW
if that is what is needed, then maybe I will do it
is their a temp fix i can do myself?
ok now I am not sure if the hotfix caused the WiFi problem or if it was trying to install busybox
i dont think it was the hot fix so I am going to post it again
i think trying to install busybox messed up my wifi but I am not sure why
Super job guys! Happy to hear the good news. Too bad I just got a Transform Ultra and listed my Prevail on ebay. Just cant deal with such a small touch keyboard. :o
with me busybox fcs before its done installing.
mine says busybox version: null
i install 1.19.2
busybox was found: /system/xbin/
i press ok
/system/xbin/ could not be mounted as RW, the install will fail
i press install anyways and a box appears and says: it looks like busybox is installed, but it does not appearyo be the version that you selected to have installed. you may want to try the installation again but this time using a different installation location.
i install 1.19.2
i press ok
mines the exact same
Question: What is the "Roaming Indicator Off" message on the notification pulldown, about? Anyone know?
i want to find how to disable that too, it is annoying
and since we are on Boost Mobile we are not allowed to Roam onto other networks anyway
i intalled the hotfix and i think my wifi works. but it is low so idk. i also read on another forum that gaps was giving people problem when trying to update and install some apps.
no but the hotfix did
well i just did a fresh install of beta1a
installed hotfix 1
installed gapps
tested wifi and it was fine
and tried to install Busy Box from the Market
now my Wifi is not working
it is the Busy Box that is messing up my wifi and I am sure the same thing happened on your system
installed hotfix 1
installed gapps
i am adding busy box to the things to avoid
why dont we make a post on the cyanogen forum? theres a section for unofficial ports. maybe some one there can help with some of the issues.
Ok so first off great work wit this love the new mod. :D only oneproblem after the phones been on for say 4 hours I go to call or recivce a call nobody can here me once I reboot it works just fine has anybody Elise gotten the same problem? And also I reverted back to shabbys mod but once I do I lose all sight of 3g. D; any help I'm on cm mod right now could use some help
