quick question. when formatting the sd card with cwm what do i select on eu xt size? theres 128m 256m 512m 1024m 2048m and 4096m,
make sure you backup SD card before you do this, because SD will be erased
the size depends on how many apps you want on it
i would try either 512 or 1024 to start with
and choose 0 for swap
I just flashed over last night, and up until just a few minutes ago I hadn't really had any issues other than the known ones. My issues started when I brought Darktremors into the mix. I redid my SD to start fresh too. Before and after flashing I made backups, but I noticed that after the last reboot that all of my apps were GONE!!!!! LMAO!!!!! They didn't show up after rebooting again either. At this point, I really thought that I was up s@#t creek!!!! I restored my last backup, and low and behold everything was back to normal and running smooth again. Apps2sd is working as it should now!!!!
Thank-you hroark, and to everybody else that brought Cyanogenmod to the Prevail. It's taking some getting used to, but the speed and smoothness is incredible.
All this is why I am letting others test this oit before I try it out myself.
all of us who try it are the reason problems get discovered and found.All this is why I am letting others test this oit before I try it out myself.
Why is this not a sticky yet? *shakes fist*
Guys just calm down I am juat not willing to screw up my only phone right now. Plus I an bashing anyone for using the beta. I was just commenting on the issuess that have cropped up iss all.
we need people who are running Froyo based ROMS to help too
for instance one person running CM discovered that they can not send MMS while connected to wifi
It will save us time if someone with a Froyo based ROM can tell us if it works on their phone
I personally dont feel like reverting back to Froyo everytime I want to see if something worked before
So you can help if you choose to do so, I do not blame you for not wanting to put your only phone on a beta ROM
It wasn't really what you said Topken, just the way you wrote it. It appeared a bit standoffish and wasn't really helpful at all to anyone.
(Not trying to argue with you just pointing out how it read to me!)Ok I have Cyanogen running perfect and also a2sd running perfect as well...i was curious should i use any of the 3g or V6 scripts with this rom???
And also are there any themes compatible with this like Honeycomb or Simple Blue??
It is most likely because when you started fresh with your SD card you cleared your SD ext data, and when you restore italso restores your sd ext data. I could be wrong though.
Will there by a bluetooth fix for this mod anytime soon...just checking..???
LoL Well let me say I am running this myself but there are issues that crop up and if you need 100% reliability for work hold off but if 95+% is fine then grab it an enjoy some interesting features, Things like blue tooth work, though file transfer over blue tooth has been reported as not working correctly I have not verified that yet, probably check that out today. Voice is fine you may need to hit mute an then unmute and it works perfectly.This really is an EPIC accomplishment and effort by hroark and team. I feel guilty for not trying it out yet, but I have gotton much too dependant on my phone for work recently and really do not have the time, energy or inclination to go though the stress of beta testing. Getting old, I guess.
That being said, I have been very impressed with the team effort on this project to get the bugs worked out and I really do appreciate it. sounds like real progress is being made on finding and fixing the bugs. I have the utmost confidence that this attitude and dedication will pay off very soon with a completely usable system without a lot of tweaks every time you boot up.
One very important thing for me is that the DarkTremor A2SD works as i have also become very dependent upon that working without a hitch. I believe I may have read that there is something similar that comes as part of this mod. I am painfully ignorant of what this will look like but apparently it must be the shit. By that I mean really good.
Actually, I am waiting on the New Optimus Good Housekeeping Seal of Approval. Also, like to hear from the WetBiker for his input.
I will be lurking around keeping up on this and pounce on it at the appropriate time.
not from me, I will be traveling for Business the next couple of days and will not have any time to work on this
the next thing that I am going to work on is the 3g data issue
it is up to all of us to find fixes for the issues, so I look foward to any fixes you can submit
i dont think I posted this in any of the first 4 posts so I am going to state it now, and this is not directed at you, dont take it personally, this is a message for everyone
do not ask for eta's
if people start asking for eta's i will purposely hold back any fixes that I come up with and only give them to people that are trying to help fix the issues
Ok no prob and thanks again for all you have done hroak and new optimus, its no prob im kinda of new to this and was just checking thats all but the rom work perfectly and im loving it lol thanks again so much for your efforts and i appreciate it alot...
