does anyone know how to get headphones to play from the headphone jack? i know they work because i use them on my ipod flawlessly but everytime i plug them in music just plays from the speaker phone,i do not think this is thw rom as ive had this problem on stock as well
What apps are ok to remove.Because I removed google search and when I went to my market it said to add an account to go to market I used Titanum Backup.I appreciate all the hard work everyone is doing I am new to this but am learning slowly thanks to android forums and espically Hroark.THANK YOU SO MUCH!!!!
Yeah I tried to the same with eclipse and got errors too. I had to stop right there and resort to reading cuz I'm not that advanced with SDK yet. Still dont know exactly why it wont load yet. Got any info on where to find out?I tried to import it into Eclipse. That was a mistake. Eclipse claims 41 errors and 14 warnings. Either I'm missing some parent files, or this is not meant to be edited in the Eclipse IDE
I went looking for the parts that <start over simplified explanation> announce that "Camera" events are handled by this app </start over simplified explanation> to see what was different between the VideoCamera and the regular Camera java files but my brain turned to mush. I'll look again later.
I suck at writing code, but I can sometimes find little syntax things that other people overlook. that's why I'm trying to help![]()
can i install over CTmod ?
add these two lines
windowsmgr.max_events_per_sec=160
debug.performance.tuning=1
should help responsiveness
I don't think you can remove apps because I tryed to remove some and caused my phone to boot loop I think hroak said he had to put maps back on to keep it from boot looping so I'm not sure but I would try to remove any and get a list also can you post ur phone summary for better help
There's a guide for this.Stupid question, i never altered prop before how do i go about adding these? have a numb ***** guide?
I removed talk,maps,TTS, and tips with no issues. I replaced rom adw with adw ex as well. Everything works great.
once you add network you have to toggle wifi on and off
im not sure if im doing this right but i try to connect it says remembered then it never connects i tried to turn on and off the wifi that did not work where do you toggle it i have also tried the drop down menu shortcut that doesnt work either ?![]()
I have used several types of head phones and the ones with most success are the ones with 3 ring jacks on the bottom
Now my phone is
Cm 7
Beta 3.5
Hot fix 2
8 gb SD card (no partion)
No app to SD
Cleanedinit.zip (flashed with cwm5)
With music player Google from ics
2
The only problem was the mic part from the iPod headphones that did not work at all (expect playing music) plz post what you have installed on your phone for better help
3rd post I think if not check a few posts back I can't post a link because I'm useing the phandroid apppretty much everything stock on cm7 except i added the the hot fix 2
btw what is cleanedinit ive seen people using it and where can i download it
i cant either im tethering on 1 bar of 3g and you could imagine whats that like
