Help D802 touch screen problem
Hi... I got another LG G2 with same problem, and remove the back pannel and it was D800 so i edit the tot file the same way you explained and it was flashed the phone 94% and flash tool says Failed to download and it reebooted and struck in LG Logo. when i try to put in download mode it goes to 1st screen of download mode and goes to fastboot mode. how to solve this problem?
I'd pull the motherboard and verify that it's a D800 (model stamped on underside of board). Sometimes the writing on the bottom of the phone is not the same model as the board. I usually tell people 80% of the time it is. You may be the 20% that causes me to make the statement. :)
hi everyone, i have the same issue as the guy with an ls980 (fake d802), so, i am on the 5.0.1 android that i updated,the touch and the sim are not working and i am lost to what should i do, i tried the flashtool combinations above, none worked i was wondering if i should do the jb twrp method or just jump to shortcircuiting the motherboard, if so what files should i download pls :)
