rangerpaul
Member
Thanks to hroark13, murderousone, interdpth, Shabbypenguin, and everyone who has helped to get a little more than expected.
Version 2.7.5.2-1 of Darktremor A2SDRequired:
-Hroark13's ClockWorkMod Recovery
- dt_a2sd_prevail.zip
-A properly formatted SD card. This means an SD with an ext4 or ext2 partition.
Install With Hroark's CWM
The best way to do this is to use odin and hroarks ee14 with cwm recovery and hroark1.2 kernel
then go into cwm recovery and partition the sd card, at that point it will create a ext4 partition then go into mount and mount /system and /data
1. Place downloaded dt_a2sd_prevail.zip on SD card
2. Turn off phone
3. Boot into recovery (hold vol up + power)
NOW'S A GOOD TIME TO MAKE A BACKUP. OK, Let's Continue.
4. Install zip from sdcard
5. Reboot system now
First boot may take a few minutes while apps are moved.
To see if it worked check the a2sdGUI now in your app drawer
or open a terminal or adb shell with root priveleges and type
you should get a status dialogue.Code:a2sd check
Download DarkTremor A2SD for Prevail here
EXT4 Rom Users
If you don't get the a2sdGUI app the first time you boot, you need to boot into recovery, manually mount system and data, and install it again. If you're on the all ext4 rom, this will happen. If you don't know what an all ext4 rom is, odds are you don't have it and won't need this step.
-inigo
Worked for me in the order above.
The only gotcha I ran into was the largest partition I could create was 4GB. I have an 8GB SC Card. I can deal with that later.
Thanks to all!
