wastedagen
Member
Hey guys
Very interesting thread.
I'm new to the forums and don't currently own an Android handset - the Desire HD is hopefully going to be my first - but I'm reticent due to these battery issues.
One question: has the 1.32.405.3 firmware update made any difference?
I know it wasn't mentioned in the bulletin but these things are often hidden or have a knock-on effect.
I also see HTC have gone for a very similar hardware platform for their flagship win7 phone (seemingly same screen, cpu and battery capacity). I wonder if this is also dogged by the same issue or if there really is something that can be done in firmware / android to increase the battery life.
I'm also assuming, with my schoolboy physics/chemistry, that a higher capacity battery in the same physical size isn't going to be on the cards...
Uri
I dunno, the first thing I did when I got my iPhone was strip it and remove the 1150mAh battery and solder in a 1600mAh one. These were exactly the same size.
So maybe soon enough they'll start popping up on ebay........
... 14 hours looks like a time for 2 or 3 recharges, in my case it looks like ~7 hour awake time is what 1 battery recharge can give you. Then it depends how much active you are. In my case it is still 21% battery remaining while being 2+24+16=42 hours since last battery recharge while having ~5 and half hours awake time.
