its not lag though is it its the battery
This is so God damn frustrating...
My battery doesn't last an entire 8 hour shift, where I'll only use it on my breaks, which is an hour a day. It's always flat (0% battery) by the time I get home and the battery usage seems to think it's down to the calendar... Tried everything...
I have got my DHD yesterday after a long frustrating comparison with SGS. I have been following this battery life thread and would like to know what is the best utility to check on battery performance. Do you guys use a native tool or a third party one?
Thanks.
I did not have SGS but know someone who has and he is very unhappy with the performance but like the feel of the phone. I do like the shape and the feel SGS also but I don't have time for the problems it is giving, so I went for the DHD at the end.Battery not withstanding, how are you finding the transition from SGS to DHD. Very interested to know if you've adjusted to the lower quality screen and if the software generally feels less buggy than the SGS.
My battery is making me really regret getting this phone.
I take it of the charge at 7.30am this morning, go to work and it is dead by 2.30pm.
I sent about 7 emails throughout the day and made 1 5min phone call. It was idle for the rest. there is something seriously wrong with the battery and my calender usage was 60%
Hi gabbyevs,
Even though the problem that you are experiencing is regarding the battery and not lag, you should definitely read this.
As Fio said the '/INIT resolution' should improve battery life as well.
What the guys at XDA-DEV found when investigating this was that the /INIT process was running and using between 70% and 100% of the CPU processing, even when the phone was idle. This explains why some people see the DHD's battery drain even when they go to sleep and the phone is not being used.
Turning USB Debugging On seems to send /INIT to its dormant form and its CPU usage goes straight down to 0%.
People are now reporting that since doing this their battery is lasting considerably more.
Good luck.
what app killer is that mate, or do all of them have an option to close them when you turn off the screen?
Hi gabbyevs,
Good luck.
Someone please help, the last 2 nights somethings been taking all my battery,
last night at 10.30 my battery was at 64% and ive not touched it all night and now its at 1%?
Somethings seriosuly wrong surely, this happened the night before as well any ideas?
I have not installed any new apps except flash player 10.1 when this started happening, a few night agao it only when down a few % when i left it on overnight!
The only idea i have is that it doesnt seem to have any signal, most of the time, does that use up alot of battery trying to find one?
I looked up battery use it says 81% cell standby 89% no signal?
Also it keeps asking to me select my time region and i select the right one and it says it cant do it any ideas?
Sorry. just me being thick here. But what's the 'accelerator'?
Ta
Dave
I'm still waiting for my DHD but a couple of questions about the battery...
I currently use an iPhone 3G with Wifi, bluetooth, 3G and push email left on. Last all day and it goes on charge when I go to bed.
Am I likely to get the same usage from the DHD? Or will it only last a few hours with all those things left on?
can a air brain lady ask when i looked at the battery it said display is taking 83% is this normal or not if not how to cut down first android phone. thanks
). For instance, my phone currently says it has 70% battery left, so it has only used 30%. The battery stats say the display has used 58%. If the phone has used 30% of its battery, the display can't have used 58%. Instead, it is 58% of the 30% used, and so the display has actually used 17.4% of the battery's overall power. Also, the fewer things that are taking battery power, the higher these percentages are likely to be. Apologies if that sounds a little patronising, but I got the impression that some people didn't really understand that.Ps i clicked the unhappy face by accident, im new and dont know how to remove it from the title![]()
I agree with the above. There does seem to be some contradiction with the information on this forum about Task killers, and what I read elsewhere on other forums etc.
It may be just me and my novice approach to android but after originally installing and using a task killer I was experiencing problems with lag and reduced battery, and since removing said app, the OS performed like the day I got it, and works like a dream now., but maybe this was due to installing the new update?
Can we get some clarification from some more experienced users on this situation. Just because 2.1 and before needed task killers, it doesn't mean there are required now... or does it???
Maybe it would be nice if everyone wrote which microSD card they're using (brand, class, capacity). Maybe it has something to do with the battery drain as well.
I've also noticed a high % of battery going to the calendar. I've got the 4x1 widget on the home screen (HTC calendar widget #3 that shows one item that's coming up) and the full page agenda view on another home screen (HTC calendar widget #2).
My consumption didn't go as high as yours, but usually around 20-30% which is still ridiculous for a calendar!
I've removed the 4x1 widget now and a couples of hours have passed & the calendar isn't even showing any consumption on the usage screen.
Did you have that same 4x1 widget running?
