With BSydz's build the camera rotation is incorrect on preview then is corrected after you take your first picture.All pictures save with correct rotation tho even the first when the preview isn't correct.Also it shows correct time and date on pictures taken.
As for the theory of the fact that video isn't working is causing the video chat apps to not work it makes sence.But the only reason why I kinda disagree is cause they where working on the 20130127 CM9 build.That's what bugs the hell out of me.If it's not working cause we don't have working video then how did it work before with that same issue.Now the only thing that isn't working with video is that it's not allowing us to record and save a video but we still get a preview.I feel that apps like Skype just use the camera in preview mode to stream the video feed.That is the only way that it would be able to work on one build but not another it seems to me.Now I know that adam is probably tired of me talking about it but it just bugs me you know.It's like your brakes on your car are worn and you replace them but then the brakes don't even work anymore at all lol.(ok that was extreme but it's the only way to compare it)
I have never seen the rotation wrong, I even did a fresh install just a second ago. The cam came up fine the first time.
Well that is the thing, they were working before the camera fixes, and all that was changed was camera stuff. It may be the encoder that is not working and throwing in to a loop. It is not just related to the cam itself, something may be getting lost in translation.
Thanks, I don't think I touched the cameraHal, it previews on the first go around fine for me. I have been working on the kernel and now the video record doesn't FC the app, but it still doesn't record. I am getting ready to go on vacation so I'll be away from my rig for a week or so, so I won't be able to contribute very much over the next week. But this should give everybody some error logs to keep them busy.re: rotation issues in PA...
I double-checked that I committed the preview rotation fix, and I did. It was the:
enableMsgType(CAMERA_MSG_PREVIEW_FRAME);
on line 625 of cameraHAL.cpp. If you have that as well, you may want to try changing it to:
enableMsgType(CAMERA_MSG_ALL_MSGS);
I basically pulled in all msm camera stuff and changed all the video stuff, see the attached screenshot. I was also working on the touchscreen drivers, I have all files from the M410 kernel except bi041p_ts.
Kernel-CM9-PA-Camera-touch-Test1.zip
