ok well when i do the button method i get the factory reset option nothing about recovery..did i do something wrong?
If you flashed CWR factory reset is void. Tap it 3 times.
nope hitting the power button will factory reset my phone it says nothing about press the power button 3 times
ok im on my pc now... ok i don't think im doing this right or i don't have the most updated cmw i don't get a screen that says hit the power button 3 times... i hold the power+the two volume buttons and release the power button when i feel the vibration and keep holding the volume buttons until i see the screen that says hit the power button three times i don't get that screen
Dude... Every one of us that have installed CWM have this screen that pips up when we want to get into CWM and we ALL have to hit the power Burton 3 times to get into it. Add long as when you installed CWM then it will be there. What methods did you use to install CWM? Rom Manager or the Installer file from within Windows? Either way if it told you that CWM was successfully installed then go ahead and do it. Heck if you want to treasure yourself then just Download ROM Manager from the market and reinstall CWM and once you see that it is successfully installed then you will know that you definitely have it but don't worry, if you installed it through either off those before then you have nothing to worry about and can just Tao the power Burton 3 times to Getty into CWM. Just believe us, we deal with thus almost literally everyday.
Sent from my LG-MS910 using Tapatalk 2 Beta-5
I AM calm, just trying to get you to understand that people aren't going to sit aorund here all day and talk you into it. We know what screen you are talking about and we deal with that exact screen every day. Now technically you WILL have ICS on your device but if you read other posts then you would have noticed that you will not have it on there for long because it is unusable. You will not jump into this ROM thing you say but you don't know that you won't have this ROM as a usable one? Either way, back to what I was saying. I am calm but you need to understand that WE know what we are doing. Permanently Erase User Data & Reset Settings? Press Power Button To Confirm And Any Other Key To Cancel.
If you are talking about this screen then you have nothing to worry about if you have in fact installed CWM. Like I said before, I am not trying to be rude or anything but want to make sure that you understand that people are going to quit helping if you just ask for help then blow it off. We know what you need to do and are actually looking at your phone in our minds PERFECTLY. I know that it came off as rude definitely and I am sorry that it seemed like that but I am just trying to help you out and make sure you do it NOW because I don't want you to be shunned like some other members on here are/have been. Now hopefully if you KNOW that you have rooted and installed CWM succesfully then maybe my quote of what I remember the screen says(Possibly even Word For Word? LoL) that it will help you decide that we know what we are doing. Shiny, Bigge, PNut, PG, LD, Fuzzy, Budde2 and others that I may not remember off the top of my head are experts on this device and can help out with almost literally anything on/pertaining to this device. Not being rude once again, just trying to give incentive. Also, if you dont have CWM installed and hit the power button it will only delete the User Data but will keep root just to make sure you know. You will be fine and after you do this you will understand that we are ALL knowledgable here and are here to MAKE sure you do things right and trust us. Let me know when you hit that button LoL because we are going to make sure you fo the rest correctly which is actually just as easy as you should be hitting that Power Button 3 times. If anything, get Google Talk as a desktop client and add us from it to talk instantly to us and make it easier. Sorry for sounding rude but just don't want you to be shunned or anything along those lines.
im not doubting anyone here but i will doubt my phone and whats installed on it and also you not knowing what i have in my hands should tell you that if im nor wanting to push a a button that is telling me it will do a factory reset on my phone i hope you would understand why i would question that and hesitate pushing power when the screen is telling me push power button to confirm this factory reset..im not trien to be an ass here i have been for a week now looking around forums (many different forums) and threads to find out how to get into recovery with out using cwm app and this is what i have seen in almost all the forums look for the words push power button three times so when i load up the screen by useing the combo buttons thats all i would see nothing else so i thought i was doing something wrong and i didn't want to bother people with this easy task until i have go to the point of not being able to go further...and the high caps gave your frustration away but no worries im cool...
update.. it just stays at the loading screen i guess i will wait for this to become stable i just wanted to see what it will look like...
Yes, now hopefully you made a back up? The same procedure is in effect for a restore for a backup just in case you didn't notice it LoL except this tinge you must select the backup you want to restore but if you have only made one backup then that is quite an easy choice to make HaHa
