epayne123
Android Expert
Installation aborted
No problem, issue will be fixed here in a little bit. Downloading right now to fix it then reupload it and report back.
Not at all to be honest because me and PG both have a testing device. Even if we did not the radios would still pick up a wireless signal and WiFi signal just not a Mobile Data signal.
Just wanted to clarify that it works now and thank you. Btw, cheers to PG; its actually pretty usable for a prealpha. I played angry birds space for a little while.once everything settled down, the game was playable. Few hiccups here and there with google voice fc, but it was expected.
Already did.And would you be okay with "Thanking Me" through the Thanks button?
I got to play with it for a bit but it rebooted and the cm9 boot animation just kept going and going... Any ideas?
Yup, there is a problem with the rebooting... There is an easy way to get past it, either wait a long time OR Wipe Dalvik Cache. I found this shortcut out after the first release and just never told anyone LoL. So when you want to reboot you must Wipe Dalvik in CWM in order to get away from the Infinite Boot Animation
I meant to honestly but at first i kept forgetting and then i decided to mess with you THEN i forgot again until now HaHa
Are the links I posted earlier of any use in helping with CM9
No, sir... Sorry. We already have the RIL being read by the OS, just have not gotten WiFi up and running yet but that should not be the problem BUT the problem is with Mobile Data.
Data isnt fully configured yet, same with wifi basically.No, sir... Sorry. We already have the RIL being read by the OS, just have not gotten WiFi up and running yet but that should not be the problem BUT the problem is with Mobile Data.
When it gets closer to to being usable it all should work out of the box.im sure if its important you already thought of it but what about the apn patch for mms to work that we had over on the optimus? wouldnt that help even a little to get data up and running?
