max25002
Android Expert
what is this for --->at least wipe dalvik
it is now
md5sum for it
Code:407e52241bad485f54fa863c8ac28f13
Code:
it is now
md5sum for it
what is this for --->Code:407e52241bad485f54fa863c8ac28f13[/QUOTE] The md5 sum for the signed zip. If you have a successful install don't worry
what is this for --->Code:407e52241bad485f54fa863c8ac28f13[/QUOTE] md5sum for the paranoid to check its validity and to ensure your dl isnt corrupted ;)
127.3MB on my hdd.how much mb is it
so what do i do with that i have to eneter it or something
yea this one has the RIL working, tho for some reason some binaries arent working til I push em manually.I'm not sure if he added theRIL into it but i will check and if not i will go ahead and do my best to get it in there. It has been a go/no go from reboot to reboot for me so we shall see
does 4g and wifi workyea this one has the RIL working, tho for some reason some binaries arent working til I push em manually.
4g isnt even on the todo list yet lol and wifi not working just yet, but I think I'm close on it.does 4g and wifi work
link me, not the same ones Shiney posted a few days ago is it? if so, I added those already.Regardless this ROM is getting a lot of progress now. @ pg or epayne did you guts add the new Qualcomm processor weeks posted this morning. Thatay help vremove some lag bc I added it and now my phone is like butter. Only theckeyboard lags for me @1ghz
assert fail? if so you can open the zip with winrar or 7zip nav to META-INF/com/google/android and dbl click on the updater-script and remove the 1st line with assert in it.ok i get an error when i flash from cw recovery what can i do?
it flash ok or did you have to remove the assert check??ok im at the home screen and i cant freaken wait no longer this is what i have been waiting for...
not as bad as the last file its a little choppy but its close i can feel it but dam good work whats up with the three soft keys ....back ..home.. below the apps button?
A assert check = check that its being flashed to the device it was intended for![]()
k kewlno i went into the wrong card on my phone i guess and installed or tried to install the half downloaded file from the forum but its at the home screen and it looks like its working so far other then the wifi and 4g...etc
