white0ut442
So I'm down with the swine flu..
I feel I should disinfect the phone. Are lysol wipes safe to use with the screen?
Thanks
Thanks
use alcohol. period.
1. Alcohol kills germs. If you want dead germs, use alcohol.
2. Alcohol evaporates quickly and leaves no residue behind like other cleaners and bleach will.
3. Other "solutions" contain water. Water = bad for electronics. You can clean a circuit board with alcohol but I wouldn't try that with water.
Turn off your device. Remove the battery. Wipe it off with alcohol wipes. Let it dry for a few minutes. Feel better.
Thanks
How about wishing the person well; I mean it's a serious illness.
I def wish you well, I hope you recover, and come back to the forum to let us know how you're progressing.
On the current thread note, we got some special cleaner for our LCD TV because some cleaners make the screen yellow. I only use that for my DROID screen.
lol...you don't think there's water in an alcohol based wipe?
