how much weight does the extended battery add? Lots of buzz saying it doesn't add hardly any thickness to the phone!
You would never in a million years notice the weight difference.
It's only 0.5mm (yes, millimeter) difference, which is close to the thickness of fingernail.How about the thickness difference?
Anyone else disappointed with the extended battery? I charged it to about 85% and now 3 hours later it's down to 50%. Does the 4G really eat that much?
Wow !! so you guys are burning through the 2100mah battery in just a few hours ??
What kind of use is this ? I don't even think the rezound would die that fast with LTE Teather going the whole time ... Hopefully after a few days we start seeing better battery life. I had read so many reviews saying that this had some of the best battery life of any Android phone even on LTE
Mine is doing just fine so far. The way I figure it I will get a minimum of 10hrs out of it.
Did you change any settings?
If someone with a GNex would download Watchdog Light from the market and check 'include phone processes' and 'monitor phone processes' on the settings, this will check the phone to see if it too has the 'suspend' bug which affects battery life. My Razr has it as do many other varied Android phones. Was wondering if it affected ICS phones or not. Hoping that in ICS it has been addressed and fixed. It's a bug that while the phone is in standby screen off just sitting unused for any length of time, suspend process uses up a majority of CPU time switching the phone back and forth from sleep. This drains battery life while the phone isn't being used.
