Does the kitkat 4.4 update
It kinda looks like this. Curiously from my phone. :D
I guess I should say that I just got this phone recently, but it's also my first smart phone. I basically understand nothing when it comes to android...
Yeah, it's the F6. It's a few different things put together. gravitybox+kk launcher Pro (L Beta), and a few things here and there. my next job is to rework the systemui.apk if I can and get a cleaner looking notification tray.. :D Wish me luck.. Gonna make it look like the kitkat (or L preview) counterpart. I think I could implement a double swipe for a second area. That actually seems feasible.
I also have a ton of performance mods installed to make it as quick as a higher end phone than it is.
Can I know what you use for the status bar icons?,
I use gravitybox.
Anyone willing to give the new systemui a try, i'll put it up in a few.
Anyone willing to can contact me on the oudhs irc chat, or on Skype (Angablade)..
That way, I can mod on the fly.
_______________________________________________________
Edit.. Here is what I think will work... Anyone willing to test it, here you go. Remember..
REMEMBER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Make a nandroid backup you fools..
If it breaks your phone and you didn't have a backup.. I WILL laugh at you.
exactly.. push to system/app and then reset the permissions to rw-r--r-- and then you should reset your phone.
It's not working. I just got up and got my phone and tested it. Just crashed a whole lot. I'll fix it eventually and move this to the root forum when it is all good. I think I know what I did wrong.
