downloading OTA now
wichita6
I felt my phone getting real hot and checked it....downloading OTA. @ 87% now:)
This was pushed to the Bionic...I did not go check for updates.
Well, I can't seem to find a screen capture program that does not require root.
Anyone know of one? free
You have it...I can't remember which one but:
Press and HOLD both the UP Volume and the Power Button at the same time.
OR
Press and HOLD both the DOWN Volume and Power Button at the same time.
__________________
.232 and holding ... Back to .905 and waiting ...sorry can't comment on it at the moment :smokingsomb:
screen capture worked on home screen but not within systems settings:confused:
Sure it works!
Do we know if this is the same leak .246? Also I am still on .230 doing fine, I think I will wait to see if there were any issue before I RSD back to .905 and OTA it.
Yes it's the same, the locked and signed version .246 is version .246, no unlocking it, adding to it, and re locking / re signing would be allowed.
Will the ICS OTA work if I am on 905?
according to this doc, the current version is 902
https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/69247/p/30,6720,8048
I just want to make sure I am on the right version to get ICS. I am sick of waiting for this update. been way too fuggin long!
Motorola doesn't do a very good job of keeping some parts of its website updated. :D
Put it in perspective:
"Weeks" beats "not out yet" which beats "don't know if it is even coming at all".
So you see how it isn't bad at all really, but hopeful and cool!
