Root Droid X 2.2 Overclock (Kernel Module w/Instructions)
I did the OTA and can't go above 1.15. My limit was the same on 2.1. Might just be by device. What are the manufacturing dates for the devices that can clock 1.3+? Are they newer? Mine is a launch day DX.
2.2 OTA here. Only getting a stable 1.1Ghz. I've tried 1.2,1.3, and 1.4. Differing voltages of each. I was able to run 1.2 for a while, but after a while it bombed. Not asking for help, just reporting results. I'll keep messing with it more. I was getting 1600-1680 Q score with 1.2 before it died (tried to save a game after playing a PSX game).
As a side note, saw a huge boost in performance of emulation and video playback. Still cant play a full 720P mkv file in rockplayer (even at 1.2), but it stutters much less. Also certain emulated games are performing at near full speeds when they didnt before (psx4droid).
Yeah Fab, I think you may have found the variable. Seems people on the OTA can OC farther.
Im still using the leak and I have had my as high as 1.5ghz. So I dont think thats it.
My manufacture date is 36/10
Good questions maybe some of the newer ones have the declocked processor supposedly in the SE edition at 1.2
Likewise I still wonder if temp load might have an affect. Do any of the high clockers have covers, or extended batteries?
but yeah I bet build date will show a difference.
I use a Body Glove rubberized case and the temps have been the same as they usually are.
I've been running 1.4 GHz at 65 vsel for about 6 hours bows.
i didn't mean to quote yours, someone else said they couldn't get past 1.1 on 2.2 OC
i'm launch day dx, had the leaked ota, now on Apex RC1
been running 1.3 ghz for a few hours now
i think the OTA X's aren't able to get past 1.15, the leak seams to do just fine past
2.2 ota here, running rubix 1.0 rom.
I can run 1.195 stable as of now using these setting (compliments of beesley)
01
echo 64 > /proc/overclock/max_vsel
02
echo 1195000 > /proc/overclock/max_rate
03
echo 1 400000000 27 > /proc/overclock/mpu_opps
04
echo 2 700000000 38 > /proc/overclock/mpu_opps
05
echo 3 900000000 50 > /proc/overclock/mpu_opps
06
echo 4 1195000000 64 > /proc/overclock/mpu_opps
07
echo 0 1195000 > /proc/overclock/freq_table
08
echo 1 900000 > /proc/overclock/freq_table
09
echo 2 700000 > /proc/overclock/freq_table
10
echo 3 400000 > /proc/overclock/freq_table
my latest quadrant is 1586 and linpack 16.71
Im on leaked and im running 1.35ghz at 68volts. Very stable. If.I knock down to let's say 60 volts, will that really help battery life.
My X was built for the original Droid X release date, can't overclock past 1.1Ghz, turtle at 1.2 even at 68 vsel. Interestingly, the phone will never crash, just turtle... Too bad, would have been happy with 1.2, 1.1 just leaves me longing for more lol.
Im on the leak and can't get passed. 1.15
I find it weird that I can run stable ar 1.35 with 2.2 leaked...onbut when I was on 2.1 I couldn't get past 1.15... im not griping ... at all.
weird. Such inconsistency with the OMAP chips
We should try to figure out who can run what and what other variables could affect inability to run above a certain limit.
-Who is on the leak and can't go past 1.15
-Who is on the OTA and can't go past 1.15
Well used a combination of a couple of peoples settings and am stable @1400 w/ Linpack 18.69 and Quadrant @1807. Looking good.
Is the .sbf leak or OTA?
Nice!! What did you end up with for settings?
