Testing darktremors a2sd and I thought I knew what is does.
I check if it's working via TB.
What I did...
Checked internal memory before downloading 20mb of apps---300mb
Checked sd-ext memory before downloading 20 mb of apps---1.66gb
Downloaded 20 mb of apps
Checked int. memory after dwnld---271mb
Checked sd-ext memory after-----1.64gb
So, I lost approx 29mb of internal
Also lost .02gb of sd-ext memory (which is approx 20mb--correct?)
So, it appears apps are going to my ext but also to internal.
Or, am I reading that wrong?
I thought if dta2sd was functioning properly, my internal should not budge.
Ran in Term. Em...repair and reinstall but nothing changed.
Using an ext4.
No apps on sd card
Cache/dalvik running from internal...not ext..(that's the way I have it at the moment.)
Running dta2sd version 2.7.5.3 beta 4
Ran a2sd check and it says apps run from sd-ext.
Just cant figure why my internal memory drops also in addition to sd-ext??
What I did...
Using an ext4.
No apps on sd card
