Hey all, I'm dying to use the Miui rom but I use the 4G during the school year, so I'm wondering if you can dual boot on the EVO 4G. If so can someone point me in the right direction.
Thanks All!
Tray262
I don't believe you can. Internal memory would be one issue along with having some way to partition the phone. You can however use nandroid backups to do the same thing. 5 minutes or so and you can be running a different set up entirely.
To add, if you SMS backup/restore, you'll be able to (you guessed it) backup and restore you messages. Just make one at the start, name it whatever, then just over write it with the next one. And restore it when you restore you nand, and make a new backup when you backup your nand (or go to a different one).
Not exactly what you wanted, but this is a viable way to swap it up on a regular basis.
Quick related question about jumping back and forth between nandroids: are the battery stats saved in each nandroid? I ask because I often try the battery calibration tips after flashing a new rom, and was wondering if I would need to redo that each time I reflash a saved setup.
Unfortunately, you will have to recalibrate your batteryThanks for the reply. Although that sucks for the idea of jumping back and forth between nandroids. Oh well.![]()
Wiping the battery stats can be tedious but it can be worth the timeHmm.. I don't think I've ever wiped the battery stats... what am I missing?
