Mikeandrd9213
Member
Thanks so much man!
so I was performing a downgrade to un-root.
then, oh no!! this happened.
The tot file is corrupt-try downloading it again. You did unzip it yes?
ZVB*****.tot wasn't compressed. dl'ed from PG's site.
Ok guys I've been trying to fix an Esteem for the better part of 2 days so I thought it might be time to consult the boards. I have an esteem that I can only boot to download mode no other button combos work and the I can't get any of the tot files to flash even with the phone being detected in dl mode and the vs910.dll registered. Any help would be appreciated. Thanks
Are you using the store version or lab version of LGNPST?Shows up as download mode on the screen and in lgnpst the progress bar goes all the way to 99 percent and fails
I have seen that twice....break the phone to fix it. Unplug the cord during the process. Get the phone powered back up and redo the process. It has worked once for me this way.![]()
The this was with zvb tot
Ok.... It finished.. 100% but the phone won't turn on or start powered off charging... So I still can only access download mode... Weird
I can't access recovery or boot into the ROM... So.. How?At this time you are to perform a factory data reset
