No prob...see my edit I was working on in my last post
Edit: if you need any clarification, just ask
I thought it was going to work.o.k..cool, now I think you are trying to install a recovery correct? forgive my forgetfulness...it's late
Edit: sorry, to install a recovery via fastboot lets try this...again, I am copying/pasting the instructions origianally posted by Ocnbrze..so credit to him
And you can use the file posted for the recovery...it is also an excellent recovery
ADB command method
1.download amon ra 2.3 from here:
PC36IMG_RA_2.3.zip
2.extract the file and then go into and move recovery.img file into the android folder you created when unlocking your bootloader.
3.on your phone after you have unlocked your phone you should be in the bootloader menu screen, select the fastboot option
4.on your computer press and hold shift while right clicking the android folder.
5.select open command window here option (windows 7)
6.enter command:
congrats!!!!!! you have just installed amon ra 2.3Code:fastboot flash recovery recovery.img
Well, that unlocked referred to the HTCdev unlock method to root.I thought it was going to work.
Command line said "writing recovery... Okay [1.544s] finished. total time: 2.663s."
But no change to phone. Clockwork mod is still there.
Thanks for trying.
Maybe I skipped a step. Step 3 you said "after you have unlocked your phone." How was I supposed to unlock it?
Your hboot is version 6.16.1002 correct?
If so, you are fully rooted, so dont worry about the unlock thing.
(btw, your hboot is the same as mine)
I just don't understand what the issue is here...not being able to change your recovery??!!!
Did you attempt to run the PC36IMG ruu provided earlier by Ocnbrze?
Yes, it will be in a .exe file tho which you can run from your computer while your phone is plugged in as your are...let me find the link.Yes I did. It said it updated 7 out of the 8 items, everything but hboot. And yes, my hboot is 6.16.1002. Could I try to install the RUU using this fastboot method?
download this to your computer and run it. Plug in your phone while in bootloader and follow the instructions.....
I'll be up for a little while longer to see how it goes for ya![]()
Just for clarification, I unplug the phone from USB, run the .exe on the computer, then plug in the phone while in fastboot and follow instructions?
My fingers are crossed so much, they're twisted loli'm already in it. It says replace image version 4.45.651.1 with image version 4.45.651.1.
I think this is gonna do it! I have a black htc screen now and I have a green progress bar on the phone!!!
yer killin me
It has to be this POS clockwork mod!I dont think so, as that ruu should've installed a stock recovery.lol It finished and rebooted.....sadly, still bootloopingIt has to be this POS clockwork mod!
Crap! Pull your battery....wait about a minute then put it back in and tell me what your bootloader says...then try to reboot.
Still bootlooping, yes.Still rebooting? I mean , bootlooping?
I'm gonna have to sleep on this and come back tomorrow cuz, I, iz tyred
One more question tho, what size sd card do you have?
I've jumped into the middle here so sorry if its been covered.
Last post before bed.
Have you tried booting into recovery from boot loader?
If it bootloops, try reinstalling recovery and then trying again
Try rerunning the ruu
This sounds an awful lot like boot loop of death, but that shouldn't affect your h boot
Yes, We did all of that. Tried installing new recover by copying to sd card. It recognizes it, acts like it updates, but actually does nothing.
Tried installing ruu from sd card. again same thing.
Tried installing new recovery with fast boot connected to computer via USB.
Tried installing ruu using update utility via fastboot and usb.
None of this could get rid of clockwork mod and the bootloop madness continues.![]()
Have you tried a different sd card? You mentioned before you had a 1GB card.Anyone can help me to solve my phone?
