I had my phone freeze a couple times today to the point where I had to restart.
One of the times was when I had Pandora running. Anyone else run into this?
Denise, it sounds like your issue may be different than mine because when the phone freezes, I lose all functionality.
By the way, did you eventually have to take the battery out to get it going properly?
To all seeing Issues with Pandora freezing. I too use Pandora a lot and have seen freezes with it. It tends to happen when the network has a hiccup. I don't think this is an OS issue though. Sometimes if you just wait it out it will fix itself or even force close. I believe its more of how Pandora is handling network lags. Most apps that require the network may cause these types of issues.
Just my .02 cents.
I think you're right. Pandora definitely makes my phone freeze. It happens when it is transitioning to another song. The screen goes blank and eventually the force close message comes up. Hopefully this gets fixed in an update!
