Root Evo4g unroot issue
LtBlkSolo
Question I was trying to unroot my evo and forget to take my screen saver off and start the ruu find but the screen saver kick in and now I get a htc logo on a black screen with one icon in ea corner and when I try to go to recovery and I get
Supersonic EVT3 Ship S-OFF
HBOOT-2.10.0001
Touch Panel-Atmel224_16ab
Radio-2.15.00.11.19
oct 15 2010,12:07:00
RUU
Parsing...(download.zip)
1 Bootloader - Bypassed
2 microp - ok
3 radio_v2 - Fail-PU
4 Recovery - ok
5 Splash1 - ok
6 system - ok
7 tp
8 tp - Bypassed
9 userdata - ok
10 wimax - ok
11 boot - ok
Partition update fail!
Update fail
This is going on every time I run RUU_Supersonic_1.32.651.1_Radio_1.39.00.04.26_release_171253
that is the wrong ruu.
I am unrooting in a few moments If I find the correct ruu I will send you the link. You need an ruu that matches your current radio version 2.15 and hboot 2.10
http://www.megaupload.com/?d=MUSAURP7 should be the right one ...pulled from section 5, after root of the root for dummies thread
Ill try like 2 diferent ones but it tell me that the rom update cant not connect your android phone. Is only work when I run the old RUU ver and the stop.
RUU_SuperSonic_S_Sprint_WWE_3.70.651.1_Radio_2.15.00.11.19_NV_1.90_release_161482_signed.
this is the lalest I got but cant get the program to recognize my phone when I plug the usb. Only recognize it if I use the old ruu and stop half way.
The Rom Utility cannot connect to your Android phone. Please check that the USB cable ant get to reedis connected properly . ERROR [170]. Cant get to recognize it
I had that problem yesterday, you should try to see if you have the right driver installed on your computer for your htc. Once you install the proper driver everything should work fine.
http://www.youtube.com/watch?v=lvMw0vBYE7c
skip to 2:40 thats where he explains about the drivers. Hope this helps.
1) You likely can't flash a PC36IMG.zip file at this time. See the instructions in the rooting for dummies guide if you'd like to try, but likely it won't work. Once a RUU is interrupted, it needs to finish.
2) You were able to start the RUU meant for an older phone because you still have S-OFF. You were supposed to flash the S-ON tool, first. Because you didn't, it started to flash, but it can't continue because you have a newer hboot.
3) Did you ever look into evolvr's advice about drivers? That's probably the best place to start.
4) Once you do get it flashed, you're going to need to do a couple of things:
a) Use the link in my sig to flash Clockwork 2.6.0.1. This is the only way to flash it, as you'll have an unrooted ROM.
b) Get the unrevoked S-ON tool from the rooting for dummies guide, then flash it from recovery.
c) Get the PC36IMG.zip that Mr. Ed posted if you want to start over the "clean" way, OR grab the hboot 2.10 stock recovery fro the link in my sig. Either one should be fine. The latter is much faster, but not as "guaranteed", I suppose. It also might not work once you have S-ON. It's up to you.
Ill try to install pc36IMG.zip putting it in the sd card but cant flash nothing. When I turn the phone on I get a Black scree w/a white HTC logo and i triangle in ea corner and then a boot screen w/all the info
HBOOT-2.10.0001
Radio-2.15.00.11.19
RUU
and nothing else.
Ill try to make a video so you guys can see I can only run 1 ruu and stop w/error after 4 minutes . Im getting desperate
Your only option is to run the correct RUU. What happens when you connect the phone to the computer? Does it prompt you to install drivers?
nop eny other RUU promp a message "The Rom update cannot connected the USB cable" only the old RUU can go thrue and stop after 62% with message "The Rom update Utility cannot open the requested files or the files or the files are damaged. The RUU cannot continue with the update".
Please get a complete RUU package and try again.
Well, forget the older one. Try redownloading the newer one, and try running it again.
yes and the bootloader is 1.0 and I istall and unistall it more than once and when I try to update to the android usb new driver tell me that the driver is up to date and stay 1.0
One question I just got my new phone from sprint and went to recovery mode and fastboot and try to run Ruu and then I got the same "The Rom update Utility cannot open the requested files or the files or the files are damaged. continue with the update". but the phone is new and is working fine. Eny suggestions?
In avoidance of sounding like a jerk.... Dude, you need to learn proper grammar... i know that there are alot of shorthand versions of words that folks use liberally, but eny instead of any(and that was just the last one i saw, it would have taken me too long to point them all out)? come on man....
