HI FRNDS,
i am new to this forum.i recently purchased a samsung galaxy phone.i am from india.before i let u know wat my problem is let give some details abt my phone.
PDA-I7500DDII3
Phone-I7500DDII3
CSC-I7500DDII5
FIRMWARE-version 1.5
BASEBAND VERSION-I7500DDII3
KERNAL VERSION-2.6.27 imtrs@se-s506#5
BUILD NUMBER-76XXCSDCBALUM6375
so these were my phone details hope they will hep any of u to help me out.
i read in this forum that d upgrade for samsung galaxy,andriod 1.6 version is available.
1.is it official release.
2.is it in english.
3.can i back up my data.
4.if d upgarde is unsuccessful is there any way to return back to my previous version.
5.does the bluetooth file transfer work with 1.6.
6.i am not able to connect my phone to pc using d micro usb.any suggestions.is it necessary to use d pc suite everytime to connect to pc.
7.when connected to pc using usb,2 folders E and F poped up but they wouldn't open however i try.d properties show 0 data and is asking to insert disk.
8.how to upgrade to 1.6 procedure.
plz plz guys help me out.................
hey
1. No. Leaked. said to be official in France
2. Yes. Be sure to remove CSC
3. Yes. using Drakaz recovery
4. Yes. Just flash old firmware same way you do 1.6
5. No. Not as far as ive seen
6. Not necessary to connect to PC Suite but it is to use USB to PC
7. Not sure the go there. Did you mount drives on ur phone??
8. http://androidforums.com/samsung-i7500/13692-how-odin-galexo-rom-s.html
and firmware is http://androidforums.com/samsung-i7500/47548-firmware-i7500xefjb2.html
but you should read these forums as there are bugs/issues with 1.6 firmware you should be aware of
RellikZephyr
THANKS FOR UR REPLY.what drivers shud i install on my phone to connect to my pc using usb.shud d drivers be installed on phone or pc.
You can get it all working without NPS as I never installed it on Win7 and everything works. In the mass storage mode it was simple plug and play, while debugging mode required the ADB drivers from either this forum or SDK.drivers are usually installed when installing New PC Suite.
pc suite itself doesnt work properly but installing it should put all necessary drivers, Provided install installs completely without error
What windows you got?
RellikZephyr
I am really waiting for 2.1.
i thought 1.6 was 29. 27 was cupcake
the unlock button seems to be working nicely in 1.6. i had a pretty old 1.5 firmware and had to hold the button down for an eternity and then sometimes it wouldn't work.
2.x and maybe 1.6 saves your settings online (if you choose to let it). The new market will also auto-install you're apps again after a factory reset! I'm not sure if it will work from 1.5 -> 1.6 upgrade, but the next time you factory reset it should remember your apps and reinstall.
Ho-hum. I've just downgraded to v1.5 again (IL3). The JB2 build is excruciatingly slow (3+ seconds to open the Settings from the home screen; worse when switching between apps) and eats battery like you wouldn't believe (60% in 4 hours, with literally nothing running).
1.6, see you later. Hello again, fast and stable 1.5.![]()
I'm using Galaxo 1.6.1 for 2 days now and I think it is a huge improvement compared to the 1.5 firmwares. Touchscreen is much more responsive, battery endurance is better, more apps are supported and overall responsiveness has improved.
Does any of you by change have tested if Wifi Tether is working with this new firmware? See: android-wifi-tether - Project Hosting on Google Code
Guys,
Please help me out. I have upgraded galaxy from H7 to donut using odin. In odin I noticed everything went smoothly. After flashing galaxy is NOT getting STARTED. :-(
Anything can I do to fix this..?
