inssane
Android Expert
What kernel are you using (speed/dev/voltage)
What ROM and version?
How long have you been running the ROM?
Does it occur under certain circumstances?
What is your minimum clock speed set at?
It seems to be hit or miss with this reboot thing, and some of us (myself included) have the low end at at least 250 (mine is 400).
So...
I have used Chevy 1.2 LV and ULV and P3 1.2 LV and have had rebooting issues.
BB 0.1 for a few days
Seemed to happen more using Nav and under load - with Nav mine clocks down to 1000.
My minimum clock is 400.
Maybe this will help the developers overall, since it seems like some have it and others don't.
So...
