Root Frustrated-usb connection
Same as Mass storage when phone is on. Should have access to sd contents on pc
Edit: do with phone plugged into PC... Should have mentioned that, lol
Yeah I figured that out. Worked just fine and came up just as Mass Storage normally would. Still can't seem to get it to work after a couple reflashes and resets.
Using cwm for mass storage is slightly less convenient, but if you're unable to get it working, it's better than nothing :)
I'm starting to think it's driver issues on my computer rather than a problem with the device. Going to try to clean up the drivers installed and reinstall them and see if that works.
Tried it to no avail. Going to buy another usb charger tomorrow and see if that's the problem. Otherwise I'm just going to assume my phone hates my computer and wants to annoy me. I'm pretty sure it's begging for the concrete mod. :D
So I finally decided to try connecting on my laptop rather than my desktop. I installed the driver and then let windows finish installing other drivers for the device and now it works without a problem. Going to have to figure out how to uninstall all the appropriate drivers and reinstall them again on my desktop so it will work on there as well.
As Rogue has just done have you tried with a different computer?
Also are the cables you have tried samsung cables? other phone cables will charge the phone but not data transfer. ONLY stock prevail, or possibly other samsung phone cables will work.
I only have one computer boss and they are stock cables.I tried cwm mass storage but nothing happened.
