dustwun77
Endeavor to Persevere :)
haven't read this whole thread so forgive me if i duplicate stuff, or worse yet, contradict...
I have hear it suggested to update prl and profile, not sure why that would help but only takes a minute.
I have an app called gps test, it gives option to clear agps and update agps, might try that.
some apps claim to 'fix' gps too, think that is all they do.
Might try a fw different sense nands.
Might try powering down and pulling the battery for a bit and press power with it out to discharge and maybe unlatch something electronic.
you already try the codes you can type on keyboard and the zip flashes?
edit: yep, duplicating, and making same mistakes regarding zips as last time. I have had to go through loading like 3 sense roms before it would work on 2 different occasions. good luck!
