nitestalkr
For those of you that want to go the extra mile and flash ZVJ firmware onto your Optimus V, click on here to follow Sammyz' OptimusV ZVJ Guide!!
That's right, you read correctly.
In the past couple of days, I've been working on a Flashable ZIP that will automagically get ANY, and ALL Optimus S ROM, to be FULLY Functional for the Optimus V.
This Project was birthed in the ZVJ JellyBean CM10 thread for the V, and now I'm bringing it to it's own thread!
With this, you will be able to Flash Optimus S roms, such as HydroRom that was built only for ZVJ baseband Optimus S Phones, and get Button mapping, SMS, Calling, Data(reactivate your phone in GB Roms), and MMS(Still WIP, need help making a universal flashable MMS fix) fixed, and for use on the Optimus V.
[info]What is currently working for this:
SMS
Calling
Data(in GB Optimus S Roms it requires reactivating your phone.)
Button swapping.
To fix MMS(apparently works on GB, just follow this for JB), follow these instructions here
[/info]
[info]TO GET DATA WORKING ON GB ROMS:
[/info]
DOES NOT WORK IF YOU ARE ALREADY ON ZVJ (USING SAMMYZ GUIDE)
[info]Things you need to know
*These patches are for ROMs built for both the Optimus V and Optimus S on any baseband/firmware.
*Make sure you are flashing the correct patch, for the correct firmware.[/info]
[box="Installation"]
-Flash your Optimus V or Optimus S Rom
-Flash corresponding GAPPS
-Disable signature verification
-Flash corresponding Patch
-Boot into ROM
-enjoy![/box]
[info]Additional Information:
Included is the ZVD radio fix. (Thanks Zakman for providing what needed to be implemented!)
LG Optimus V key layout fix (Thank you YoshinJaa for clarifying what needed to be changed!)
To fix MMS(in JellyBean), follow these instructions here (Thank you asadullah for providing the link.)
Enjoy!![/info]
[info]Downloads:
*Patch to be used on ZVD, ZV4, ZV5, and ZV9 radio's to flash ZVJ Roms(Thanks ThatGuyLurkin for fixing this for me)
ZVJ to ZVD patch- Opt V-07312012.zip (209.7 KB)
*Patch to be used on ZVJ radio's to flash ZVD & Optimus V Roms(these need feedback)
ZVD to ZVJ patch-Optimus V-07292012.zip (1.33 MB)
[/info]
If anyone AT ALL think they'd be able to contribute (Universal flahsable MMS fix) that would be AMAZING!!
And PLEASE report any Bugs you may(or may not lol) experience with this patch fix.
(I am available practically 24/7 for any help and support with this.)
SMS
Calling
Button swapping.
[/info]
Thanks ThatGuyLurkin!!I got it working by install Hydro Rom, booted.
Connected to wifi, downloaded Solid Explorer and replaced files from the zip and set permissions. And there we go.
[/info]
-Boot into ROM
-enjoy![/box]
Enjoy!![/info]
[info]Downloads:
[/info]
