jayfromthebay
Hey everyone, my I had my evo on charge and went to sleep with remote pc running, when I woke up it was really hot and kept restarting at the 4G animation. I mean, it was seriously on repeat, says 4g, then starts over again, then sprint.. 4g and restart. I can't get it to boot and I need my phone ASAP!
I've tried booting with the usb connected, sd card in and out, everything. Nothing works. I even went to the recovery like I was doing an update to get it to at least reflash the firmware or something and it FAILS. Keep in mind, I updated a couple weeks ago with the newest EVO software manually (the one without the fps cap), so the file should still be on the SD card exactly how it was when I updated the software last.
This is what it gives me:
E:can't open /cache/recovery/command
E:can't mount DATA:data/recovery/log
--Install from sdcard...
Finding update package...
Opening update package...
Verifying update package...
E:failed to open /sdcard/update.zip (No such file or directory)
E:signature verification failed
Installation aborted.
E:Can't mount DATA:data/recovery/HTCFOTA/update_result.log
E:Can't mount DATA:data/recovery/OMADM/update_result.log
E:Cant mount DATA:data/recovery/log
What the hell do I do!?!?
Thanks, Jay
Thanks, Jay
