Root Help Lg Esteem Stuck
im a idiot i installed a rom for a different phone put it on my sd card installed it & Now my phones stuck on the boot screen . it wont even go into recovery mode my computer makes the sound like its plugged in i opened The Lg Support Tool That Read My Phone But My Computer Dosent See it iCant Get into it thru the computer but the program reads it ididnt realize what iwas installing until it was too late .
See if Android Commander can see it.
If not what version did you have ZVB,C or ZVD.
See if LGNPST can see the phone. http://androidforums.com/esteem-all-things-root/479734-guide-downgrade-ms910zvc-ms910zvb.html
what im going to try to do is put my sd card into my old lg & delete the zip file iput in there my older lg phone reads the memory card on my computer
If commander doesn't see the phone your only hope is trying to downgrade from ZVD to ZVB. Usually this is the last hope and a lot of times it works. So cross your fingers and follow the downgrade link I posted up above. Gotta install several files and what not so just follow the directions and take your time.
itryed to register the VS910.dll file & a popup comes up saying
The Module C:\Users\Anthony\Desktop\LG\VS910.dll was loaded but the call to DllRegisterServer failed with error code 0x80020009.
For more information about this problem, search online using the error code as a search term.
Make sure all anti virus and firewalls are off. It should install with no issues. Its something with your computer so check everything.
still dosent work. on my administrator: command prompt says "the task has completed. Warnings occurred for some attributes during this operation. its okay to ignore the warning see log . %windir%\security\logs\scesrv.log for detail info. iLooked up the log found it this is what it says
Thursday, August 23, 2012 5:29:21 PM
----Configuration engine was initialized successfully.----
----Reading Configuration Template info...
----Configure User Rights...
SeImpersonatePrivilege must be assigned to administrators. This setting is adjusted.
SeImpersonatePrivilege must be assigned to SERVICE. This setting is adjusted.
Configure S-1-5-19.
Configure S-1-5-20.
Configure S-1-5-32-544.
Configure S-1-5-32-551.
Configure S-1-5-32-559.
Configure S-1-5-32-545.
Configure S-1-1-0.
Configure S-1-5-6.
Configure S-1-5-21-3465108624-3058635224-2074156223-501.
Configure S-1-5-32-555.
Configure S-1-5-80-0.
Configure S-1-5-80-3139157870-2983391045-3678747466-658725712-1809340420.
User Rights configuration was completed successfully.
----Configure Group Membership...
Configure Users.
Group Membership configuration was completed successfully.
----Configure 64-bit Registry Keys...
Configure users\.default.
Configure machine\software.
Configure machine\software\classes.
Warning 5: Access is denied.
Error setting security on machine\software\classes.
