Root Help Lg Esteem Stuck
still dosent work. on my administrator: command prompt says "the task has completed. Warnings occurred for some attributes during this operation. its okay to ignore the warning see log . %windir%\security\logs\scesrv.log for detail info. iLooked up the log found it this is what it says
It's something with the PC. A program or something that keeps it from registering. It happens a lot but unfortunately it can be several problems that cause it.
Try this.
Right click on the dll and select open with.
navigate to C:/windows/system32 and select REGSVR32
See what that does.
iput that in the CMD
regsvr32.exe "C:\LG Electronics\LGNPST\Models\VS910.dll
Now it says
"The Module^ Failed To Load Make Sure The Binary is stored at a aspecified path or debug it to check for problems with the binary or dependent files
The specified module could not be found
Now it says
Okay do you have the dll saved in that spot you entered or on your desktop? make sure you enter the path from which the dll is located.
it finally registered
Thank You So Much it worked now ijust have to follow the other steps now
still says emergency total processing 32% its sub processing the master bin
Awesome. Sounds good. Sometimes people have had to do this and when they came out of it they were in test mode. Hopefully you wont be in test mode. Regardless, I've got a fix for that too :D It's a little more detailed then this. But dont delete LGPNST till we know for sure ;)
Glad to hear everything is working again! And yeah i would love to bring it unfortuanltly im broke :( and cannot afford a device at the moment
