agentc13
Daleks Über Alles
Shouldn't make a difference. There is nothing but that folder in the MOBILE drive?Its all those same 7 files, although not in that order, dont know if that makes a difference or not
That is the same thing.It didnt say unzip, I extracted it.
Yeah, that is the images of the phone completely stock. When you put it in the MOBILE drive it should boot fine and be on the stock ROM.This was the file I downloaded.
http://www.noxtek.com/android/triumph/good_triumph_mobile_image.zip
I think so, but it is taking me forever to download it. I am pretty sure it is the other set of .img files you need.It is downloading..is this the file they supposedly took down??
Yeah, go ahead.In the meantime, do you want me to delete everything on my e drive, since Im still in download mode??
You only need one. If the one you have does not work, delete everything from the drive (also check for hidden files).Yes, its taking me forever to download it too, only at 16%. Do you want me to delete the image file on the drive now, or do I need that in conjunction with this new file??
In windows click on Tools > Folder Options > View. Then select the dot next to "Show hidden files, folders, and drives".How do I check for hiddn files??
Press ALTthere is no tools option, usually its in the upper right hand corner on a webpage, but when im in windows explorer, I cant find it
Not sure, you can PM me though, and I usually answer those pretty quick and can pop on to help if I am free. You should be good with those files, and can use the phone on stock for a day or so until you could get more questions answered.I pressed tools and view hidden files and nothing came up.
On 79% right, also, this places closes in 20 minutes, Will you be on tomorrow, nso we can hopefully continue this as I have no idea what Im doing, or else if we wanted to continue tonight, (as they keep their wifi on, I would have to shutdown and power back up in the car to continue tonight.
