Morpheus274
So if I try kingroot on my zv5, will it brick my phone?
Probably not, considering the latest version of KingRoot should be 4.9.6. Most likely, if a crack comes through on root, it'll come from this forum or XDA.Is this real?![]()
Zv5 May Have Fixed,Or Added Bootloader, fastboot mode HAve you successfully Been Able to access It? On Zv5Renegade: Root can be achieved on the zv3 version of the phone, but we have not successfully accessed the bootloader yet to be able to achieve permanent root on zv4. It may help us solve this if you could try various methods (KingRoot, Poot, adb, etc.) To try and root your zv5. It is a new update, so we know very little about its root-ability
my wifes stylo 2 was on v4 and I updated her to v5 ill check hers tonight to see if fastboot is back, I did try the latest kingroot on v5 with no success.Zv5 May Have Fixed,Or Added Bootloader, fastboot mode HAve you successfully Been Able to access It? On Zv5![]()
That sucksNo fastboot on v5...
How Did You Try To Access It?No fastboot on v5...
U did download mode don't work on my zv4Holding volume down while the phones off and then plugging it in while holding down, just like i do on my z3.
Nobody that I'm aware of.So nobody is working on root for the lg g stylo 2 plus?
Sure does, just hope for KingRoot some time in the near future.That sucks
Hmm,Any difference In Recovery Mode?Holding volume down while the phones off and then plugging it in while holding down, just like i do on my z3.
How Big Is Zv3s,System.Img? Some One Sent Me A Img Of 3gb Can You Confirm This for me?And If Its smaller Please Send Me Yours . And anyone with a lg stylo zv4 i happen to have a update.zip from zv3 I Think It Might fix you guys not being able to enter fastboot( it may be a bug in the ota update that made you guys unable to get into fastboot ,well thats what happen to my broken phone,Long-story-short i brought a already messed up Device has been having problems for a very long time but i cant turn it in to the store its to late),I Also have a zv4 dump i can clearly see (Aboot.img) in the files which I Think Is Bootloader From what i No so The thing is there must be a way for zv4 to boot into fastboot/bootloader...####(Update in recovery mode using adb)### Your basically downloading zv4 again!
From v4 noHmm,Any difference In Recovery Mode?![]()
