Darkner11
If you asking about Kingroot, it is an app to download on your phone.Do i just download from phone then launch? Or through computer? or are there different steps i can take to get better results?
Also need to wipe all cache and data in stock recovery that might help don't hurtI've got a Cricket Stylo 2. Tried used kingroot 4.9.6, and it said it was successful, but now my phone gets stuck at the LG logo at boot. Tried doing a factory reset to no avail. I think I'm out of luck.
power down your phone then hold power + volume down it will boot into recovery mode there is a option to apply a update through adb or any basic adb commands and if you go to the option in recovery to boot to bootloader that will put your phone in fastboot mode. Also if you power your phone down and hold volume up while plugging in your phone to the power cord via wall plug or computer it will boot into download mode i believe that is for flashing our .kdz firmware files thru lg flasher program for pcThanks for the reply
Do You Have Access To Fastboot,Or Recovery? (Assuming Thats What You Used To Factory Rest)I've got a Cricket Stylo 2. Tried used kingroot 4.9.6, and it said it was successful, but now my phone gets stuck at the LG logo at boot. Tried doing a factory reset to no avail. I think I'm out of luck.
(I Already Have The Ota ,Thanks Anyway.)DO You Have Access To Fastboot On Your Computer,I Posted A System.Img,This Should Allow You To Bring Your Zv4 To A State In Which It Can Gain Root;Also Your Phone is (BOOST LG Stylo 2, LGLS775ABB MM 6.0.1 ZV4) Correct?If it will do you any good, I have an official update (OTA) captured... logcatted phone, found URL. Its 454.4mb, unzips to 1.02gb.
Let me know, coolbeans2016 is good contact for me @ outlook......
zach
That's because it is a relatively new phone and not a lot of people have it. LG released the Stylo 2 PLUS a few months after the Stylo 2 so more people are probably going for the newer phone. Not the best marketing decision.
So, am I correct in that, with the zv3 version of the phone, permanent root can be obtained? Should we not just find a way to revert back to zv3 and then go from there?? That is, if the KingRoot method doesn't work
Yes it is, but there is no fastboot. When you do ADB reboot bootloader it just boots back to desktop. Any terminal requests like trying to install busybox (no root) ends with some messed up responses..........(I Already Have The Ota ,Thanks Anyway.)DO You Have Access To Fastboot On Your Computer,I Posted A System.Img,This Should Allow You To Bring Your Zv4 To A State In Which It Can Gain Root;Also Your Phone is (BOOST LG Stylo 2, LGLS775ABB MM 6.0.1 ZV4) Correct?![]()
This phone is a beast. Would love to have root. Almost 2K requests on Kingroot, but no root yet.
when you exit out do you see a error caled Kingroot has failed to start?
So why did you post a link to car parts?http://shop.gpgindustries.com/category/gcprokey-team-products_154_en.html
found where this unlocked bootloader on Sprints LGLS775..........
Thats not car parts! Lmao...So why did you post a link to car parts?
