Morpheus274
Tanx for the hard work guys. Can't wait for full root on zv4.!
I can get into recovery I'm on zv4Has Any Zv4 Been Able To successfully Boot Into Fastboot Or Stock Recovery? I Found A Website that Explains how to boot into fastboot more clearly Then How I explained In My Older Post.
http://www.hardreset.info/devices/lg/lg-stylo-2-ls775/fastboot-mode/
Does It Have The Option To Get Into Bootloader?I can get into recovery I'm on zv4
Ok Thats Good That You Have Recovery!Yes but it just reboots the phone
I'm on zv4 on that app u said to use for the boot image what do I need to have checked ?Ok Thats Good That You Have Recovery!![]()
It Should Say "Boot" And Download "es Filemanger" to ToFind Where it is,But You Need Zv3 To Get Temp Root To Then Get This Then Send It To Me with Google drive Or Your preference.Dident You say Your Wife has zv3?I'm on zv4 on that app u said to use for the boot image what do I need to have checked ?
Yes I see what I can doIt Should Say "Boot" And Download "es Filemanger" to ToFind Where it is,But You Need Zv3 To Get Temp Root To Then Get This Then Send It To Me with Google drive Or Your preference.Dident You say Your Wife has zv3?
Kenny 1215 was wondering if u can help me I have the same varient of lg stylo 2 from cricket wireless and i have a problem I messed with the mixer_paths.xml file that controls the sound settings on the phone and now I have no sound whatsoever also I didn't make a backup of the original file I was wondering if u could make a back up of urs and give me a copy I would really appreciate it since I haven't came across anyone having the cricket wireless version. Thank u.My biggest problem is i dont have. A computer im always a trail and error type person got hundred phones here that ive practiced and learned on messed up and some that are great but this lg stylo 2 k540 from cricket wireless is beating me up
Give me a fewKenny 1215 was wondering if u can help me I have the same varient of lg stylo 2 from cricket wireless and i have a problem I messed with the mixer_paths.xml file that controls the sound settings on the phone and now I have no sound whatsoever also I didn't make a backup of the original file I was wondering if u could make a back up of urs and give me a copy I would really appreciate it since I haven't came across anyone having the cricket wireless version. Thank u.
Having problems uploading imgIt Should Say "Boot" And Download "es Filemanger" to ToFind Where it is,But You Need Zv3 To Get Temp Root To Then Get This Then Send It To Me with Google drive Or Your preference.Dident You say Your Wife has zv3?
Hm? How,How Big Is It? What Website are you using?Having problems uploading img
100meg I believeHm? How,How Big Is It? What Website are you using?
The Boot.img :O Should be around 10/20 mbs (I Think yea im wrong) Anyway send it Useing this website http://www.filedropper.com/100meg I believe
What Happened? You Still Cant Upload The IMg?100meg I believe
She using her phone grrWhat Happened? You Still Cant Upload The IMg?
Still can't up load it grrrrWhat Happened? You Still Cant Upload The IMg?
Your On the phone trying to upload it? Have you Tryed Google drive or The website i listed? This Might Work But If Your On Your Phone Trying To Do It,it May Not work.what are you using to upload the file? (EDIT### if you dont no how to use google drive use thisStill can't up load it grrrr
I Am Pretty Sure That That the mixer_paths.xml file From Any Lg Stylo 2 Varient Should work,You should ask Someone with a zv4,or zv3 to help you..Kenny 1215 was wondering if u can help me I have the same varient of lg stylo 2 from cricket wireless and i have a problem I messed with the mixer_paths.xml file that controls the sound settings on the phone and now I have no sound whatsoever also I didn't make a backup of the original file I was wondering if u could make a back up of urs and give me a copy I would really appreciate it since I haven't came across anyone having the cricket wireless version. Thank u.
Can u link it I can't find that oneDid anyone try framaroot 1.9.8, gandolf exploit for root. Chainfire has a new system less for superSU as well.
