Yeah you can just take someones zip... unzip it...replace said image. Zip with 7zip and put on SD card as pc36img.zip. and flash from hboot.
I have a program somewhere that does everything....reformats image and flashes it to phone in minutes
first off, i have the image in .rgb565 already and every single "how-to" says to put it in the tools folder in my SDK folder.... i have no idea where or what my SDK folder is.
whats the best kernel to run with CM7, best battery life, minimal choppiness (i know every phone reacts differently but what are some that people are running and work great??)
im currently running: netarchy-toastmod-4.3.4-cfs-havs-more-nosbc
I'm not sure if anyone picked this up, but I don't think Toastmod is compatible with AOSP....is it?![]()
netarchy has provided universal kernels that work with AOSP roms. Look here:
[Kernel]netarchy-toastmod, Stable: 4.3.1 Beta: 4.3.4 (17-Mar-2011) Now With HDMwIn - xda-developers
at the bottom of his post are the universal kernels.
okay well, i converted the bmp to np, renamed my splash1.bmp.np to splash1.img
put that along with android.txt into a seperate folder, compressed into a zip, dropped onto my SD card, ran fastboot... did the same thing where it said "parsing pc36img.zip" for a split second and i rebooted and nothing happened. what am i doing wrong.
