Are you getting an error message on a computer I don't recall ever seeing an android device give a directory like in the error message you are getting.
IIRC, you'll get that error message when you select "install update from SD card" or whatever it says.
The update.zip one perhaps? I could see that happening if you did not have an update.zip on the root of your sd and choosing that option. Does anyone ever do the update.zip method at all any more?
I am almost tempted to test it out now, just to see if it would work.
