WUESTSIDER
Member
Okay, now what was that update suppose to fix???? My wifes HERO still has extreme lag when making a call. The phone appears to have no noticeable changes at all.
I have been reading that this update actually breaks the ability to root your Sprint HTC Hero. That is even if you use the Universal One-Click or UnrEVOked methods.
So, if you planning on getting this update be completely sure you do not want to root your Sprint HTC Hero. If you do apply this update, the only way you could root would be to reinstall the original Android 2.1 build .5 RUU.
Which should not be an issue for many, because if they root they will most likely want to install a custom Rom, so installing the 2.1 build .5 would only take minutes extra.
True, but I figured giving everyone all the information at hand was worth the post. I like knowing little things like this before I proceed with a major change in my devices.
I am sure they will develop a work around for the root killing ability of this update anyway. Then flashing back to the stock Android 2.1 RUU will not even be needed.![]()
One bad thing I did notice, and I do not know if the update caused this or not, I did not get text messages yesterday. After rebooting this morning I started receiving them again. However, I had not had problems to texts since the first couple of weeks I had the phone, so it has been quite awhile. Coincidence maybe, or maybe related to update.
I did my update this morning, it says update version 2.31.651.7?
Is that the new update? I just installed it, haven't messed w/ anything yet..
I have been trying to get the update but when i check for it i get the circling "checking" box and it goes on forever, until i hit back or home. I dont think this is normal, but i'm not sure. This doesnt happen when i update profile or prl or firmware...it checks then says no new updates, but with the software updates it just checks forever. Is this normal?
I got the update yesterday. It's pretty amazing. I have no lag anywhere. Dialer is definitely a lot faster. I can answer calls faster. The keyboard comes up and responds to my touches a lot faster. The browser auto-rotate is pretty much instantaneous now. Before the update, I had huge lag with all of the preceding issues.
I am LOVING this update![]()
Should the update be available to everyone now? I heard it was going out over a week or so.
