Root How to enable wifi tether
Status
Not open for further replies.
TCTTomT
I have a samsung galaxy prevail I beleive its rooted I used one click and that gave me
Superuser however it didnt load clockwork mod which apears to be necisary. I have tried to
Use odin to get clockwork however at first it kept saying it couldnt deleat 3comm engion and
Now odin wont recognise my phone is even attached. Not to be neady but instructions on how to use odin,install clockwork,and enable wifi teather and install other roms would be great.
Whoever can help I would apretiate it,
Thankyou in advance for any and all help,
Tom
Start with the basics TCTTOM - did you put the phone into download mode? Do you have the appropriate driver? (I assume you do since you used "oneclick")
"Oneclick" rooting does not come with CWM if that's what you're implying.
is there another way to root my phone that comes with cwm i used one click and now im trying to flash with odin however odin is givin me a hard time. this is my first time flashing anything so there is a strong chance i am doing something incorect.
I have...
downloaded drivers
rooted with one click
downloaded the cmd files and odin
Unziped them
put stick.zip on sd card
shut off phone
put phone to yellow downloading screen
opened odin
pluged in phone (and now odin is recognizing phone again)
i put the HROARK_SPHM820..ops file in the ops areaand the HROARK_CWMv5_SPH-M820_Odin_1P in the one package area
I checkmarked the one package
than i clicked start (with the sd card out of the phone)
now it starts the process and contines for 15 minutes with next to no progress
I have...
downloaded drivers
Unziped them
shut off phone
opened odin
Have You Uptil Now Flashed This Mobile Phone?
I have...
downloaded drivers
Unziped them
shut off phone
opened odin
I have...
downloaded drivers
downloaded the cwm files and odin
Unziped them
shut off phone
opened odin
Have you tried re-downloadi ng the cwm package? Your ownload could b corrupt. And Odin is currently the only way to install cwm
There is strong rumor that the new prevails that have come with gingerbread EJ06 installed will not allow you to use odin
Tom
If all you want is wi fi tether you DO NOT need cwm.
check this one
http://androidforums.com/galaxy-pre...2451-wireless-tether-infrastructure-mode.html
this is the odin problem the farthest it has gotton is this point
<1> Added!!!
<1> Detected!!!
<1> odin mode.. check platform verification.
<1> START!!!
<1> odin mode.. do file mapping..
<1> check download environment.
<1> e - big partition size!!
<1> Delete Comm3engine
i have tried it on more than one computer and with more than one prevail i would like to be able to use wifi tether too but just need help getting through the steps the first time
Problem solved i have CWM 5 now the issue was that i had an outdated version of odin I read that i 3.95 is what we use for the prevail however it did not work untill i used 4.42 it did not work the first time i ran it 3 times but the fact is that it worked odin is definatley not blocked...yet
All, couple of things:
1. Thread is being moved to the all-things-root sub-forum
2. Thread is being closed because of Boost Mobile's Official Term's of Service regarding wifi-tethering:
http://androidforums.com/boost-mobile/455626-boost-mobiles-official-tethering-policy.html
According to the Boost Mobile's Terms of Service (ToS) available at http://support.boostmobile.com/service_policies/terms.html
Boost Mobile's official policy about tethering is
Specific Terms & Restrictions On Using Data Services
If your Services include Web or data access, you also can
Status
