Make the Wireless Network Location workwhat will flashing th modem do?
ah. i thought that was part of the rom. sorry. and last question. (sorry but i dont want to screw up) i load these just like i did the kernel, right?
Using Odin you got it up and running yet?ah. i thought that was part of the rom. sorry. and last question. (sorry but i dont want to screw up) i load these just like i did the kernel, right?
So you just put the cl14 file in the 'one package' slot in Odin and flashed it the same as ZE9.2? Then after the reset you did the same with the modem? (keeping the OPS and all of those other options the exact same?)yeah, i was able to get it going and load 8.3 then 9.2 today. but when i loaded cl14 it never got off the samsung logo. had to pull the battery.
Anyway, now that I know what to do, my Moment will not restart in download mode anymore????
Ideas, anyone???So you just put the cl14 file in the 'one package' slot in Odin and flashed it the same as ZE9.2? Then after the reset you did the same with the modem? (keeping the OPS and all of those other options the exact same?)
I've been sitting here with the new samsung logo flashing for about 2mins. How long does it take?but when i loaded cl14 it never got off the samsung logo. had to pull the battery.
Edit:NVM, it went through. Wow, that took almost 3mins to boot!
I think this should help....Zefie's Custom Kernel - Samsung Moment WikiZE09.2 turned off the autostart of the dropbear ssh deamon, which is okay, but after running dropbear-ctl start I'm still not able to log in. It seems the password has changed. I thought that maybe Zefie wanted us to set our own password, but it appears that the passwd command is not installed. Any ideas how this is supposed to work?
It is stored in a settings file.. hell if i can remember where zefie told me he put it...ZE09.2 turned off the autostart of the dropbear ssh deamon, which is okay, but after running dropbear-ctl start I'm still not able to log in. It seems the password has changed. I thought that maybe Zefie wanted us to set our own password, but it appears that the passwd command is not installed. Any ideas how this is supposed to work?
u have the USB cable unpluggged, right?Well, here's a bitch. I tried to Zef my phone for days. Would get to setup, then stall. I found out from the Zefster himself that you can't flash a phone if Firefox is open.Anyway, now that I know what to do, my Moment will not restart in download mode anymore????
Ideas, anyone???
).What are you still doing here? Go be 'that guy'!!! I can't wait to hear how it goes!Bump so this doesn't get piled under all the new flurry.
