afastyzfr1
Member
Thanks but I'm one that won't take money. If it comes to it, we can go to chat and do it that way.
Well I really appreciate your help, I'm a noob at this stuff
started bootlooping
Yep, wipe data/factory reset & wipe cache partition are in there
Ok, well now you have SU again and clockwork so we're at least in a semi-happy place. You COULD try the 2nd part of the earlier post where you end up wiping/formatting everything only this time installing a rom. But that's more work since you want to be unrooted at the end of all this. Might get your phone up and running temporarily though.
At any rate, whatever you decide, go have a good weekend and we can reconvene next week and try the "Messed Up Partitions" thing if you'd like. That would have been my last ditch plan, I have seen it fix some phones in worse shape than yours. If you wanna go that route, go ahead and get some things ready. Download the "Parted" that's mentioned in that thread. Also, research "Android SDK" as best as you can. It takes quite awhile to get set up so look for one of the many tutorials on getting it set up. Any good tut should tell you to install it on the root of your C: drive. If it doesn't, find a different tutorial.
I will PM you my email address so we can chat (assuming you have a gmail account) or at least you can reach me more quickly when the time comes.
I had to create an account to say thanks for posting this guide. I just used Option 1 to unroot from rooted 2.3.4 (with s-on) so I can return this refurb phone I got.
Also, I want to add that this PB31IMG works just fine for unrooting SLCD dincs and you don't have to worry about getting the black screen issue that would happen with the old leaked 2.1 PB31IMG. (I was kind of wary about this and couldn't find an answer as to whether this would be a problem--so, don't worry!)
Thanks again!
-Kyle
1. Since megaupload is gone, I had to get the 2.3.4 PB31IMG.zip from a different site (Stock Images | PvilleComp's, I hope it's ok to post the link here). The MD5 checks out OK from that site, though it doesn't match the one provided here from the now defunct megaupload link. That concerns me a little.
I believe the one linked there is an older version although it appears the RUU is the new one so I would go that route.
2. The 2.3.4 PB31IMG.zip I downloaded contains a radio as well as the ROM. It's the same radio I'm already running (2.15.10.07.07) - am I ok to flash this over what I currently have, since it's the same baseband?
No problem.
3. Will this also return recovery to stock (I have CWM recovery), or is that something I have to do in a separate step? If I have to do it separately, in what order do I do it - before I return it to S-ON using Unrevoked or after? Before flashing PB31IMG.zip or after?
Flash s-on file (zip) using CWM first, then run the RUU to return to stock. You don't use Unrevoked at all during this procedure. Re-examine the OP for this step. And yes, the RUU procedure will replace CWM with the stock recovery. There's 2 parts to this...flash s-on file in CWM, then run RUU. Then you end up with an s-off phone that's also unrooted.
4. Finally, in addition to CM7, my phone has the EXT4 4 All mod installed (/data and /cache are formatted ext4 instead of ext3), do I need to be concerned about this?
Not sure on this one. My instinct would be that this may cause an issue when trying to run the stock rom. I'm thinking you could use clockwork to format /data and /cache although I'm not sure what the default format method is within clockwork. You could then proceed to unroot although if you go that route, it might almost be best to load a stable rom first so you could then unroot by way of RUU with a bootable phone. Bottom line, you're on your own with this one, I'm just offering my thoughts which may be right or wrong.
Hey guys, I need help.
I had CM7 and need to return to stock. I installed the S-On and that worked fine. Tried installing the RUU (went fine from what I can tell) and now my phone just sits at the HTC Incredible screen. Same when I try to turn on with Vol Up and Power button pressed. Have also tried installing PM31I.zip through HBoot, but still freezes at the HTC Incredible screen. I've waited about 20 minutes and doesn't proceed further.
Goodness, this seems to be a common theme lately. Since my Megaupload links are dead, could you point me to the exact link/file you used to RUU?
WARNING:
Ok, I think I see what's going on here. That file that several people have evidently been using is not good. It states that it's hboot 1.02 and also, it's only 7.18 MB in size. We need to locate the true 4.08.605.2 RUU and hope people can get back to normal.
