Hello !
I got my new phone recently on my birthday, February 14, and up until now everything has been fine.
Last night I was watching videos on my phone while plugged into to a charger. My phone was really hot and after a couple of videos my phone gave me message which said something about switching to ACD charger because of voltage or something....? I'm sorry, I don't remember exactly.
So I'm like, okay I guess I should switch chargers and get off the phone and let it charge. I was replying to a text message before putting the phone away and it started to mess up(froze up, kept sending me back home even though I hadn't pressed the "home" button). Then, i slapped it in the palm of my hand *frustrated*. And she shut off.
I tried to turn it back on but after that....it hasn't been on since last night...Also I wasn't using the charger my phone came with, if that matters.
Please, help me if you can ! Thank you ! >n<
Hello Sonyunii. Welcome!
Well, first of all let's get the "tips" prefix changed to "support," because you're not offering a tip.. *blip* .. there we go.
Now, as I read along then came to, "...I wasn't on the charger my phone came with, if that matters," I saw what mattered.
The stock charger is the way to go, or a replacement from the factory, although we do see 3rd party chargers and cables/USB etc doing fine on some devices, we also see the sort of issues you're describing most often with non-stock charging apparatus.
As to remedies for your device's issues.. I'd be inclined to have a factory tech look at it. But you can first try removing the battery and sd card and sim and putting it all back in and then going into recovery mode for a factory data reset. If it boots up you needn't go into recovery, just use the FDR in the privacy menu (I believe that's where it is on the EVO.. look around if not, it's in there somewhere
If it won't boot up, use the button combination which brings you to the recovery menu and do the FDR from there:
- Remove the battery, wait for a few seconds, then reinsert the battery.
- Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
- Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
- Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
