HTC EVO slacker Radio issues
pcsperson
Apr 17, 2010
128
24
Anyone have problems with it streaming, while keeping it in the same orientation. The reason I bring that up it was an issue in the the incredible forums I believe is where I read it.
The problem: It would seem while playing the song, it would catch up to the buffer even thou I have 5 bars or Wifi. Then is just hangs, the buttons on the EVO become non responsive. If I hit home enough times I can get a the wait message to come up or force close. Anyone else have this problem? I only noticed it after the last update, and I had install Android task killer after it.
Umm I am not following y'all on what the problem is.... When does it hang up?
While streaming. So it typically will stream a song or two, but then it looks like the player catches up to the buffer. When I Was talking to the chat support person it did, at 23 and 57 sec of a 2 mins song, and 4 mins songs respectively. Then after you get an error code, from what I have read is generated by android, I normally get Error Code -1, and 11. Then slacke asked you to push play to resume. Another way the problem happens is it can play a dong randomly stop then just go to the next Artist. Again after 0-50 secs, the time seems random. Then the played will hang, or freeze you phone, if you are luck you can just hit the home button a few times, and force close it otherwise you are suck with a black slacker radio screen.
So that is what people are seeing.
Edit: Also the reception does not matter nor does it matter if you are in WifI, also I have had the problem with it in both orientation side and vertical.
Upvote 0
BEST TECH IN 2023
Smartphones
