Root i dont have operating system anymore please help
Kimi1996
Okey, so i tried to update my system to android 4.2 and htc sense 5.0 and i made mistake i wiped cache data and i think like i wiped everything, i can acces to bootmenu sd card and recovery but if i reboot my phone it says no os istalled do you want to continue or something like that, i havent rooted the phone, just wiped the files i have no back up or anything what should i do to get my phone to work
Can I have the model? Cricket US or European?
Which K2 variant do you have? K2_CL, K2_PLC_CL, K2_U, or K2_UL? You can see this on the bootloader (HBoot) screen towards the top.
tAMPERED
UNLOCKED, cant access to hboot
That is your HBoot ;-)
K2_UL PVT SHIP S-ON RL
HBOOT-2.00.0000
RADIO-1.15.40a.00.04
OpenDSP-v9.2.0268.1214
eMMC-BOOT
Mar 14 2013,22:10:43:-1
You are S-On. This "rom" that you flashed.... Does it contain a boot.img inside of this zip? If so, you will need to flash it using fastboot on your computer. The command will be as such:
Code:
fastboot flash boot boot.img
Code:
Hey, isn't there a K2_UL deodexed 4.2 on XDA? Maybe he can just flash er through recovery.
Code:
flashing failed. and i gont have zip folders any more on the phone
my phone automaticly installed the systemupdate from wifi network
Ok, so you received this update from the actual provider. Do you have a custom recovery installed on your device? Either CWM or TWRP? If so, that was your mistake. An OTA can't be applied through a custom recovery. Must be done through your stock recovery. I'm gonna send you a link to an RUU. Requires windows, and your device plugged in to your computer. Run the RUU and it should detect the device and go from there. After it finishes, your device will be restored.
i have twrp folder and inside it backup folder but i wiped the last backup folder an made new after wipe which doesnt have the real backup
You should have never done that. That backup is there so when you do something to your device and it screws it up then you have the ability to fix your device by restoring it with your backup. Wiping your backup literally makes no sense lol.
Anyways, I cannot provide you with an RUU because you are S-On and on Jelly Bean. The RUU is for ICS which requires you to downgrade the HBoot which can only be done if you are S-Off. As of now, this is really the only thing I could find available for the K2_UL. Its a Rom. Place it on to the root of your external sdcard.
K2_ul (LTE): k2ul_JB_2.14.401.6_stock_odexed_03_06_13.zip - Mirror
Md5 Sum: 5C3BDDBAD1690794925284AA2E11150B
How to install:
First of all:
Download the zip file.
Wipe/format data/system/cache/dalvik cache, factory reset.
Flash the zip through custom recovery.
Htcdev.com unlocked users who are not S-Off have to extract the boot.img from the zip file and flash it afterwards over fastboot via PC with the command:
Code:
Then reboot your device.
can i get stock recovery anywhere?
Yes, I can provide you with one, but it won't do you any good until you get your device working again. You need to install that Rom I shared with you first. Do that, and then I will provide you with the stock recovery.
