Root i dont have operating system anymore please help
nope, I just saw a stock ROM posted on jmz's site that is 4.2.2.....corrected
Lol, the Rom is where we ran in to problems with her lol. Fastboot, adb, adb sideload, boot.img, extractions, it was a mess bro lol.
bootloader sd checking
no image
no image
no image
on the top reads *** UNLOCKED ***
OK.
So, your phone is unlocked, likely rooted at some point or in progress, and I can see that it's an HTC.
To begin, three things -
Please verify that it's the One SV for me so I'm clear we're in the right place, thanks.
Please power down, remove the sd card, and power up - does it solve the problem?
If not, let's get to the bootloader - power off, hold volume down while powering on - it will say tampered, unlocked, at the top - please write down everything, line by line, from the top through the date in your reply.
We're having some server problems so posting may be difficult, sorry.
hello sir
i have HTC 4G LTE
i can't intall os in my phone . give message like no image.no image.
i download many k2 serial os but until same message come..
i am sending my phone image and also power on situation of phone..
my phone boot is already unlocked ..
and also battery behind written like :-- PL80100 LTE 5VDC 1A
give me same suggestion and also give the os download link.
Please download the Mini-SDK -
http://androidforums.com/threads/adb-guide-updated-2014-11-11.443072/#post-5389081
Unzip the sdk-tools.zip and it creates the sdk-tools folder - I do not think you need special usb drivers right away.
Windows Explorer, shift + right click on the sdk-tools folder, choose Open command window here.
Phone - from the first picture - tap FASTBOOT so it says FASTBOOT at the top. Plug in to PC. It will say FASTBOOT USB at the top.
Command window say -
fastboot getvar all
Command window -
Alt+space for menu, E for edit, select all, copy, and paste into your reply here.
Remove the meid and serial numbers, those are private.
After your reply I can check for a recovery installer for you.
