M
ModdingMyMind
Guest
Okey its done![]()
Yay!!!!!!!!! FINALLY!!!!!!! Hahahahaha
Now reboot your device
Okey its done![]()
thank you so much for your help, you are so nice guy, you helped me for hoursYes.
Type, cd then click the space bar.
now drag and drop the folder holding your fastboot file in to the command window and press enter.
Then, type and enter, fastboot flash boot boot.img
where do i put this imghttps://docs.google.com/file/d/0B-lW8w03i5cwVV9JUTBZcjdfSkU/preview
Stock recovery.img for your device.
fastboot flash recovery recovery.img
how do i erase this recovery thing my phone was fine until i installed it
What do you mean? Originally you were trying to install an OTA so you could upgrade to 4.2.2 with Sense 5. You can't do that with TWRP. It has to be done with a stock recovery.
However, if you wish to put TWRP back on your device then put it on there the same way you put the stock recovery.img on your phone.... I would hope that you are starting to see a trend here with this process lol.
Okey I'm le back ... ... I saw the little conversation..![]()
Take over for me haha. I need a break ;-)
my system doesnt get onh anymore after i installed thatWhat do you mean? Originally you were trying to install an OTA so you could upgrade to 4.2.2 with Sense 5. You can't do that with TWRP. It has to be done with a stock recovery.
and so doesnt recovery from boot menu
when i put my phone on after htc quietly brilliant there comes a picture on the phone is triangle and ! in it same happens if i go to recovery
fastboot flash [B]boot boot.img[/B]
Hahahahaha...
You accidently flashed the stock recovery.img to your boot partition. Take that boot.img we discussed earlier and flash it with fastboot again:
Code:fastboot flash [B]boot boot.img[/B]
looks like I'm late for all the fun, why didn't we just RUU?
She was S-On and on JB. RUU is for ICS. Would require a downgrade in the HBoot.
they also have 4.2.2 that would have worked with S-ON
